Old 12-Jul-2014, 3:01 AM   #1
dshep
Tough Location, Need Some Help
If there is someone out there that can help us figure out if we can get OTA tv and if so what equipment we would need to buy we would be forever grateful! Our contract will be up with Dish later this summer and would love to go back to antenna tv. It is a tough location http://www.tvfool.com/?option=com_wr...e1c6708d64dc10
Thank you
dshep is offline   Reply With Quote
Old 12-Jul-2014, 7:30 AM   #2
I'd go with an Antennas Direct 91XG + Antennacraft Y10713 + RCA TVPRAMP1R. Mount outside, clear of obstructions such as trees and structures. If mounting on a common mast, place the 91XG at the top and the Y10713 about 4' below. This means that a 10' mast (or chain link 'top-rail') is needed.
Old 20-Jul-2014, 8:09 PM   #3
dshep
Thank you so much for your suggestions, I am going to give them a try. Any guesses on the ability to receive an NBC channel?
Old 20-Jul-2014, 9:35 PM   #4
Long shot on NBC. KUSA is your only chance.
Old 20-Jul-2014, 9:54 PM   #5
The Y10713 is the best shot you have at receiving real CH-9. If that fails, diehards would consider ganging or stacking two or even four Y10713's (Arguably extreme measures.)
Old 23-Jul-2014, 5:49 PM   #6
To see if signal strengths improve at higher antenna heights.
Please Make and Post 2 more tvfool reports.
40 feet antenna height above ground.
60 feet antenna height above ground.
Old 5-Oct-2014, 1:04 PM   #7
dshep
I purchased the 2 antennas you recommended, have them up and mounted, but still working out best way to get co-ax into the house and best placement of the pre amp. Do you recommend a specific type of coupler to join 2 antenna cables together?
Old 5-Oct-2014, 2:18 PM   #8
timgr
The RCA TVPRAMP1R recommended above will mix the signals from the two antennas. Connect the Y10713 to the VHF port and the 91XG to the UHF port. This will give you a single coax lead-in. The preamp mounts on the antenna mast and uses phantom power supplied through the coax cable, from somewhere indoors.
Old 5-Oct-2014, 2:48 PM   #9
Follow the instructions that came with the pre-amp for "separate" antennas.
Make absolutely certain that you do not put a power-blocking splitter between the pre-amp and its power inserter.
Make certain the FM Filter is "On" or "In". Do not assume the switches are set as the instructions and markings indicate, verify them.
