Old 9-Jul-2014, 7:28 PM   #1
jp1017
Antenna recommendation in Chicago 'burbs
Hi, here's the link to my signal analysis:
http://www.tvfool.com/?option=com_wr...e1c6299baa72a6
I'd like to get the HD signals from the following (WBBM, WFLD, WGN, WMAQ and most importantly, WTTW (PBS).
I'm okay with a roof mount, (approx 25ft high) but aesthetics is a concern. I'd rather not have a giant 60s-style antenna on the roof. Smaller or cooler looking would be great. Thanks in advance for your help!
jp1017 is offline   Reply With Quote
Old 10-Jul-2014, 9:27 PM   #2
“Smaller or cooler” will translate into lower performance.
An Antennacraft HBU-33 is the smallest antenna I can suggest. The Winegard HD7694P is similar in performance. If you have trees to aim through, I'd step up in size.
If we were neighbors, you'd see a fairly traditional looking antenna on my roof. Perhaps an HBU-44, HBU-55, HD7698P or the combination of an Antennas Direct DB8E + Antennacraft Y10713 (or at least a Y5713). I'd combine the two antennas with the dual input RCA TVPRAMP1R preamplifier.
Old 11-Jul-2014, 2:36 AM   #3
jp1017
Thanks so much for taking the time to reply. I was hoping the ANT751 might work, but that was probably too optimistic. There are a couple of trees in the line of fire, so I'll check out the HBU-33 or 44. Thanks again.
