Old 13-Jun-2014, 9:02 PM   #1
red fuji
I am in a very difficult position-reception.
http://www.tvfool.com/?option=com_wr...e1c61e1c838129
2Edge path, local mountain. But I am only 32 miles from towers. I tried different angles , tilts, VHS on top of UHF, UHF only... little success. What else should I try here? Any possible way to get a decent signal ? there has got to be something I can do !
I am almost to the point of giving up and going back to Cable-but not without a fight. I really need an out of the box solution . any equipment suggestions, tweeks or special set-up?
With my current setup I would have to raise the antenna to about 500' feet to get a decent reception-is that even possible without a tower and guide wires? There has got to be a solution out there that’s worth exploring.
equipment:
CM7777 Channel Master
91XG
AntennaCraft Y-10-7-13
30' high
The Tower for the seven stations I need are all 32 miles away on Mount Wilson, Los Angeles 320 True Azimuth.
not sure what stations the 91XG is best suited for -but I think I need something else that is best matched for just these seven stations.
2.1 43 CBS UHF ( bad reception)
4.1 36 NBC UHF (worst reception)
5.1 31 KTLA UHF (worst reception)
13.1 13 KCOP VHF
11.1 11 KTTV VHF
9.1 9 KCAL VHF
7.1 7 ABC VHF
red fuji is offline   Reply With Quote
Old 13-Jun-2014, 11:03 PM   #2
How big is the hill/mountain that you're behind? If it's big enough and you are too close behind it, the mountain often wins.
The Antennacraft is for 7, 9, 11, & 13. The 91XG is for everything else.
Old 14-Jun-2014, 2:13 AM   #3
Antenna System #1.
For Improved Reception of the North West Group of Digital Broadcast Tv Stations/Channels.
Install , DB8e , Current UHF Channels 14 thru 51 antenna aimed at about 308 degree magnetic compass direction.
And install the , Y10-7-13 VHF high band antenna aimed at about 308 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone , tablet and etc. compass.
Connect the , DB8e and Y10-7-13 antennas together with a ,
http://www.antennacraft.net.
10G221 preamp.
For 1 Tv connect use No splitter.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
To add the reception of and or improve the reception of.
KHIZ-LD , Real VHF low band digital channel 2 , ZUUS Country Music.
KRVD-LP , Real VHF low band digital channel 5 , Religion.
Connect a , http://www.antennacraft.net.
Y5-2-6 , VHF low band channels 2 thru 6 antenna.
To the Y10-7-13 VHf high band channels antenna with a , HLSJ = High band/Low band - Separator/Joiner.
http://www.hollandelectronics.com/ca...-Diplexers.pdf.
Antenna System #2.
For Improved Reception of , KVCR-DT , Real UHF band digital channel 26 , PBS Networks.
Aim the 91XG UHF band digital channels 14 thru 51 antenna at about 65 degree magnetic compass direction.
Connect the , CM7777 preamp to the 91XG antenna.
The 91XG antenna system is a Completely Separate Antenna System , Separate splitters , Separate coaxes , All parts Separate from antenna system #1.
A , Separate Tuner / Tuner Recorder , is used to receive KVCR-DtT - PBS , at each Tv location.
http://www.epvision.com
