Old 13-Jun-2014, 11:45 AM   #1
asgeyer
Pennsylvania - Antenna Help
Good Morning,
I've been waiting for Aereo to be offered in my area (east of pittsburgh), however who knows what will happened with the supreme court. So I thought I would look into OTA antennas. I bought a cheapy one from Lowes and tried it and got 1 local channel through it (WPXI-NBC). But that was it, and I want to try to get the local CBS and FOX channels for football broadcasts come fall as well. I'm currently renting so an indoor attic / window antenna would be best. I'm not sure how my landlord would feel about me putting an antenna on the side of the chimney.
Here is my TV Fool report:
http://www.tvfool.com/?option=com_wr...e1c68118ba3c15
I was thinking about purchasing something like this:
http://amzn.com/B00APPDX86
My question is, will this work to pick up CBS and FOX? Am I too far from the broadcast stations to pick up a good signal with an indoor antenna? Can you recommend a setup that you feel would work best? Thanks for the help! I've already learned a lot the past week reading through the forums and I really appreciate the help.
Thanks,
-Andrew
asgeyer is offline   Reply With Quote
Old 13-Jun-2014, 10:08 PM   #2
asgeyer
No help? Is my location / situation a lost cause?
Old 13-Jun-2014, 11:07 PM   #3
Lost cause? Maybe. Unrealistic expectations, yes.
Old 14-Jun-2014, 3:41 PM   #4
To see if the signal strengths improve of the weaker signal strength tv stations that you will like to receive.
Please and make and post 2 more tvfool reports at 40 and 60 feet antenna heights.
Old 16-Jun-2014, 6:59 PM   #5
asgeyer
Thanks for the help! I spoke to my landlord some more and I may be able to mount something on the side of the house. Or mount it to the outside of one of the attic windows in whichever direction would give me the best reception. I would still rather have an indoor antenna but understand that might not get me any channels due to my location. At this point I'm open to any options that will work. Here are the reports you asked for.
40 feet height:
http://www.tvfool.com/?option=com_wr...e1c6b33a6dced5
60 feet height:
http://www.tvfool.com/?option=com_wr...e1c66b00875c99
Thanks again!
Old 16-Jun-2014, 10:45 PM   #6
For reception of these Digital Broadcast Tv Stations/Channels.
WWKH-CA , Real UHF channel 47 , IND. and Retro Tv Network and Live Well Network.
WPXI , Real UHF band channel 23 , NBC and Me-Tv.
WWCP-DT , Real VHF high band channel 8 , FOX and ABC.
WNPB-Tv , Real UHF band channel 33 , PBS Networks.
KDKA-TV , Real UHF band channel 31 , CBS.
The smallest antenna I can recommend is a
http://www.antennacraft.net
HBU11K antenna
installed Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East North East and South South West.
Aim the HBU11K antenna at about 208 degree magnetic compass direction.
Test reception without a antenna system amplifier.
If a amplifier is required then install a , Antenna Craft , 10G201 preamp.
A , HBU33 antenna installed above the Peak of the Roof will be better for reception.
If a antenna system amplifier is required then install a , Antenna Craft . 10G201 preamplifier.
Here are some and not all antenna mounts that do not make holes in the roof.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218 , ronard(2224) .
http://www.ronard.com.
A Tv Antenna that is Designed to Look Like a small satellite dish is the
http://antennacraft.net
HDX1000 Broadcast Tv Antenna.
The HDX1000 will also be install Above the Peak of the Roof so that the Roof and Building Are Not , obstructing , impeding , blocking , reception in the directions of , East North East , South South West.
The HDX1000 will also be aimed at about 208 degree magnetic compass direction.
The HDX1000 has a built in amplifier so a added amplifier is not required.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind including your own roof and building in the directions of reception.
Last edited by teleview; 17-Jun-2014 at 5:03 AM. Reason: Clarify information and typos.
