Old 11-Mar-2011, 8:02 PM   #1
re_nelson
KTVT and KFWD supporting documenation
Concerning the Dallas-Ft. Worth market, here are the FCC documents to back up the ERP values I mentioned as needing correction yesterday.
KFWD BLCDT-20090724AAB
Channel: 9
Maximum effective radiated power: 11.1 dBk 13 kW
KTVT BLCDT-20090612AGF
Channel: 19
Maximum effective radiated power: 28.75 dBk 750 kW
(Note: KTVT took over KTXA's facility on 4 AUG 2009 and is still using that plant)
re_nelson is offline   Reply With Quote
Old 17-Mar-2011, 2:33 AM   #2
re_nelson
Perfection!
With the two changes for KTVT and KFWD, the TV Fool data for the Dallas-Ft. Worth market is faultless for 201103150616.
The good news is that facilities have settled down after a period of flux since the June 2009 transition. Not much is due to happen here aside from a few LPTVs lighting up.
Thank you very much for your commitment to accuracy which sometimes doesn't get the appreciation it merits.
Old 18-Mar-2011, 2:34 PM   #3
tripelo
Originally Posted by re_nelson View Post
Thank you very much for your commitment to accuracy ...
Yes, the motion is seconded.
Recent updates look fine & appreciated for the central KY-TN region also.
201003100130, dallas, kfwd, ktvt
