Old 29-May-2014, 1:46 PM   #1
Cribbagejim
Help With Antenna Choice - Maine
I am looking for recommendations on an antenna. Below is my TV Signal Analysis Result at 20'. My camp has a metal roof and no attic. The camp is right on the pond with trees all around. I also listed the channels that would be great to get in order of preference. Any additional ones would be great, but I can't see it - lol
I have spent a fair amount of time researching your site. It has been very helpful. There are so many choices! I think I need a UHF antenna Mounted as high as I can and I would have a fair chance.
Thank you all in advance and let em know if you need any more details.
http://www.tvfool.com/?option=com_wr...e1c66a6c98f4d1
WPFO-DT
WGME-DT
WMTW-DT
WCSH-DT
WPXT-DT
Cribbagejim is offline   Reply With Quote
Old 29-May-2014, 1:54 PM   #2
I'd suggest a DB-8E for UHF and a Y10-7-13 for VHF with a TV-PRAMP1R The key to weak reception of NBC and CW is a dual input preamp. That prevents overload of the UHF preamp by the strong PBS station on VHF.
Old 29-May-2014, 2:26 PM   #3
The tvfool report is antenna height of 20 feet above ground.
Do not delete the tvfool report that is 20 feet above ground and make and post
2 more tvfool reports , 40 and 60 feet above ground , so as to see if signal
strengths improve of the weak signal strength Tv stations in the Red reception
zone , and the 2 Edge Path Obstructions=hills/mountains , improve to 1 Edge or
even LOS=Line Of Sight , reception.
