Old 30-Apr-2014, 12:15 AM   #1
rctvfool
Mismi,FL
Anyone in the 33177 zip area?
I'd like to install an attick antenna with concrete tile roof, about 12 feet high. Pretty common roof for my area. Roof has some metal gutters built into it.
I know what channels I should get with an outdoor install but would like to know if anyone in my zip code has done this
I know that Denny's EZ HD should work best of all.
I've read much about tv reception and see that there is no mystery to it.
Exact location, height, antenna type, and splitter use, pre-amp requirements are crucial.
You inputs would be appreciated
rctvfool is offline   Reply With Quote
Old 30-Apr-2014, 12:46 AM   #2
Please make and post a Tvfool radar plot and channel list report.
Use the Exact address to make the report.
Make the antenna height in the report 25 feet above ground.
A antenna height of 25 feet above ground is a reference antenna height that provides a good evaluation of the Tv stations/channels that will be received.
