Old 24-Apr-2014, 10:17 PM   #1
Hansk
Choosing a setup
Here is my tvfool report: http://www.tvfool.com/?option=com_wr...e1c691a56fe986
Looking for the right antennae and preamp for my location and where to buy from.
Thanks advanced,
Hans
Hansk is offline   Reply With Quote
Old 25-Apr-2014, 9:22 AM   #2
I'd opt for a two antenna system.
Consider an Antennas Direct DB8E + Antennacraft Y10713 + RCA TVPRAMP1R preamplifier.
Start with both panels of the DB8E facing about 290° (compass) and the Y10713 pointed at about 260°.
You'll do best with the antennas outside, clear of obstructions.
Mounting hardware and cables, http://www.3starinc.com/ & http://homedepot.com
Antennas, http://www.antennacraft.com/index.html, http://www.antennasdirect.com/ & http://amazon.com
Preamp, http://amazon.com
Old 26-Apr-2014, 6:44 PM   #3
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , West North West , West , West South West , South.
Install a Antennas Direct DB8e antenna.
Aim one panel at about , 289 degree magnetic compass direction.
Aim the other panel at about 259 degree magnetic compass direction.
Buy the DB8e antenna at , www.amazon.com
Install a , www.antennacraft.net , Y10-7-13 antenna aimed at about , 259 degree magnetic compass direction.
Install a , www.antennacraft.net , 10G221 preamplifier .
Connect the , DB8e , UHF antenna to the UHF connection of the preamp.
Connect the , Y10-7-13 , VHF high band antenna to the VHF connection of the preamp.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com/90991.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Home Depot has , 10 foot 6 inch lengths of 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , makes good antenna mast.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Last edited by teleview; 26-Apr-2014 at 9:40 PM. Reason: Clarify information and typos.
