Old 15-Apr-2014, 9:48 PM   #1
graywolf121357
help with antenna's
I have gone and got my address and read out. Just was wanting to know if there is a an tv antenna i should have.... what channels I could get.. so on... here is my info... http://www.tvfool.com/?option=com_wr...5b94a9c27099bd
graywolf121357 is offline   Reply With Quote
Old 16-Apr-2014, 7:38 AM   #2
A Simple reception situation.
Receive -->Many<-- Digital Broadcast Tv Stations Channels.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South West , South , North West , East North East.
HBU44 antenna aimed at about 222 degree magnetic compass direction.
10G201 preamplifier.
The FM radio interference trap of the preamplifier will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics, HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception with a Tv antenna and so do buildings and other obstructions in the directions of reception including your own roof and building.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Do Not channel scan for only Analog Tv channels.
Go into the Tv Setup Menu and select and channel scan for ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ .
The ATSC-Digital Broadcast Tv Stations Channels.
Last edited by teleview; 16-Apr-2014 at 4:56 PM. Reason: Clarify information and typos.
