Old 20-Mar-2014, 2:38 PM   #1
elliold
Question Reception help in Auburn, AL
Good morning.
I am extremely interested in cutting the cable and switching to OTA television. I have a limited number of channels available in my location and the basically come from only 2 directions.
I would love to get NBC (especially WSFA), CBS, ABC, Fox, PBS and CW if possible The link to my report is below.
http://www.tvfool.com/?option=com_wr...5b94a433c988e7
I only plan on sending the signal to 2-3 TVs. What kind of set up would it take to get channels from both Montgomery and Columbus? Can I do it without a rotator?
Thanks in advance for your help.
elliold is offline   Reply With Quote
Old 20-Mar-2014, 4:53 PM   #2
Will you be forced to aim through nearby trees in either direction?
Old 20-Mar-2014, 6:54 PM   #3
elliold
Most of the trees around my house are to the north and west.
South and east are relatively clear.
Old 20-Mar-2014, 8:56 PM   #4
I'd try a single antenna solution as a start. There's a fair chance you'll get useable reception from the rear of an antenna.
Try a Winegard HD7698P, Antennacraft HBU-55 or HBU-44. Point at about 112° as a starting point. Be sure to sweep left and right of that starting aim point, looking for the best compromise of aim. An RCA TVPRAMP1R preamplifier would be useful when driving a 2 or 3-way splitter.
If you can't get acceptable reception with a single fixed aim antenna, a second antenna can be used. For the group of signals in the SW direction, consider an RCA ANT-751R or even a Winegard HD7694P. To use both antennas as a part of the same system, you have several options: http://forum.tvfool.com/showthread.php?t=2882
Old 22-Mar-2014, 3:04 AM   #5
elliold
Thank you so much for the help.
One other question, though. There is a small airport near my house. Could it affect OTA reception?
Old 22-Mar-2014, 3:38 AM   #6
It could. If the airport is a busy one, the problem may be much more noticeable. The large antennas I've suggested are already the primary defense against the intermittent signal reflections caused by a passing plane.
