Old 19-Mar-2014, 10:38 PM   #1
slapkey
New setup help in Greenville, SC
Hey folks,
We're going to attempt to dump DirecTV in our new house, possibly going OTA+Tivo as an alternative. I'm looking for help choosing antenna and any other equipment (splitters, boosters, etc...) that I might need.
We'd like to get ABC, NBC, CBS, and Fox.
If possible, I'd really like to mount it in my attic instead of outdoors. If that's not an option, let me know.
Thanks!!
TVFool Report: http://www.tvfool.com/?option=com_wr...5b94b3ce1a9e03
slapkey is offline   Reply With Quote
Old 21-Mar-2014, 5:52 PM   #2
Attics and the Inside of Buildings ARE NOT a reception friendly environment and NEVER WILL BE a reception friendly environment.
Start with the antenna in the attic , if reception situations happen in the attic that are not resolvable with antenna aim adjustments and antenna location adjustments in the attic then move the antenna to above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North West , North North East , South South East.
HBU11K antenna aimed at about 350 degree magnetic compass direction.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.summitsource.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing , Blocking , Reception.
The Best Practice for Reliable Reception is to install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tuners will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select and channel scan for ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Last edited by teleview; 23-Mar-2014 at 7:02 AM. Reason: Clarify information and typos.
Old 23-Mar-2014, 5:47 PM   #3
slapkey
Thanks so much! Big help
