Old 19-Mar-2014, 10:04 PM   #1
mojoab
Antenna recommendation in SE Idaho
Im cutting the cable. Problems reported from friends say they can't get local Fox and CBS ant the same time. CBS is 40 miles away. I'd like to receive both without adjusting it everytime. Im looking for local only.Here is my data.
http://www.tvfool.com/?option=com_wr...5b94a21a104292
Id like to mount this outdoor on the house.
Thanks in advance
mojoab is offline   Reply With Quote
Old 20-Mar-2014, 7:35 AM   #2
A Simple reception situation.
HBU11K antenna aimed at about 186 degree magnetic compass direction.
The aim direction will receive all the channels you will like to receive , And More , and will also receive , KXPI-LD Real UHF channel 34 , FOX and MyNetwork.
The directions of reception at your location are , North West , East , South South West.
Install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Trees and tree leaves obstruct reception.
A antenna system amplifier will most likely not be required for 1 or 2 Tv's connected.
Buy the HBU11K antenna at Antenna Craft or http://www.amazon.com.
Last edited by teleview; 21-Mar-2014 at 3:34 AM. Reason: Clarify information and typos.
Old 20-Mar-2014, 11:44 AM   #3
That doesn't make any sense since both networks are carried on the same stations. If one is received, the other must also be received unless the receiver's settings are awry.
BTW, the TVFool listing for KFXP as Fox is incorrect. That station is most recently shown as being silent (off the air) and is undergoing a change of ownership.
Old 20-Mar-2014, 2:27 PM   #4
mojoab
Thanks for your reply. The local Fox affiliate used to be managed by the local NBC afilliate in my town. It now appears to be managed by the ABC affiliate in Idaho Falls.
Maybe that is why he couldnt get both at the same time. I dont know.
Old 20-Mar-2014, 9:40 PM   #5
mojoab
Thank you Teleview
Old 20-Mar-2014, 11:36 PM   #6
Here is the answer to your private message question about the 186 degree magnetic compass aim direction.
Directional antennas such as and not limited to the HBU11K antenna receive the best in the forward direction.
A little less at front angles to the antenna.
Less at back angles to the antenna.
Less at the back of the antenna.
And receive the least amount of signal directly on the sides of the antenna.
Looking at the Digital Current Plus Pending Applications Included Tvfool Channel List and Radar Plot Map.
Your reception location is in the center of the radar plot with Tv stations in the directions of , North West , East , South South West.
Keeping in mind about how a directional antenna receives.
The Tv stations to the , North West and East are Strong signal strength.
The one Fox Tv station , KXPI , UHF channel 34 , is weaker signal strength , so aim the HBU11K antenna at about 186 degree magnetic compass direction.
http://en.wikipedia.org/wiki/KXPI-LD.
Here is some information about , KFXP .
http://en.wikipedia.org/wiki/KFXP
Last edited by teleview; 23-Mar-2014 at 8:31 AM. Reason: Clarify information and typos.
Old 21-Mar-2014, 2:06 AM   #7
All you have to do is get 34 or 36. That will get Fox and CBS.
