Old 14-Mar-2014, 2:07 PM   #1
daklprice
Looking for rooftop antenna help
Hello, looking to give it to the man by saying GOODBYE to cable and install an antenna. I have an old, SOLID, steel tripod type tower that is approximately 15 feet high. I plan on purchasing a decent mast to hopefully get me to at least 25 feet. I posted both 20 and 25 feet links below. I plan on running cable to 2 TVs only. My primary goal is to pull in the 4 main stations but most definitely Fox. Any other stations are a bonus. My big concern is I live in a old neighborhood with large mature oaks. Many oaks. Budget is around $150. Any assistance would be appreciated. Thanks, Dean
20'
http://www.tvfool.com/?option=com_wr...5b949787dc5df0
25'
http://www.tvfool.com/?option=com_wr...5b942ea0165df6
daklprice is offline   Reply With Quote
Old 15-Mar-2014, 12:13 AM   #2
Install 2 antennas.
Install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
Aim 1 panel at about 60 degree magnetic compass direction.
Aim the other panel at about 140 degree magnetic compass direction.
Buy the DB8e antenna at , http://www.amazon.com
Istall a , http://www.antennacraft.net.
Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 140 degree magnetic compass direction.
Buy the Y10-7-13 antenna at , AntennaCraft , or , http://www.amazon.com.
Install the 2 antennas on one antenna mast separated by about 3 feet.
The DB8e above and the Y10-7-13 below.
Home Depot has , 10 foot 6 inch lengths of , TOP RAIL chain link fence PIPE that is good for antenna mast/pipe and price is low at about 10 dollars
10G221 preamplifier.
Also can buy the 10G221 preamplifier at , http://www.amazon.com
Connect the DB8e to the UHF connection of the preamp.
Connect the Y10-7-13 to the VHF connection of the preamp.
The preamp is operated in the separate antenna mode.
The FM radio trap is in the , in/on , position.
Buy the , HFS-2D and HFS-3D splitters at , http://www.amazon.com , or , http://www.hollandelectronics.com.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception are , North East , East , South East.
The Y10-7-13 , VHF channel 7 thru 13 antenna is for reception of the Weak signal strength.
WWMT , Real VHF channel 8 , virtual number (9.1) , CBS and The CW.
WZZM , VHF channel 13 , ABC , is Strong signal strength and will be received by the , Y10-7-13 antenna.
Last edited by teleview; 15-Mar-2014 at 8:23 AM. Reason: Clarify information and typos.
Old 15-Mar-2014, 12:40 AM   #3
daklprice
Thank-you!
