Old 11-Mar-2014, 5:27 PM   #1
Kona Blue
Need an Antenna for a double wide (metal siding)
Below is the link to my location and I am looking for the smallest antenna that will do the job about 12 off the ground. Any suggestions? Thanks
Kona Blue is offline   Reply With Quote
Old 11-Mar-2014, 5:45 PM   #2
tomfoolery
Forgot the link.
Old 11-Mar-2014, 5:49 PM   #3
Kona Blue
Sorry about that.......
http://www.tvfool.com/?option=com_wr...5b94d5068d353a
Old 11-Mar-2014, 7:07 PM   #4
Yes the metal siding of the double wide does a excellent job of blocking reception.
Install a , www.antennacraft.net , HBU11K antenna above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North East , East , south East , South , North , North West.
Aim the HBU11K antenna at about 50 degree magnetic compass direction.
Use a Real and Actual Magnetic compass to aim antenna.
The Tv reception is strong signal strength at your location.
For 4 Tv's connected use a 4 way splitter.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions in the directions of reception including your own roof and building.
Multi-Path Reflections Tv Signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Go into the Tv Setup Menu and select and channel scan for ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Channel Scan for the ATSC-Digital Broadcast Tv Stations/Channels.
DO NOT select and channel scan for cable tv channels.
Last edited by teleview; 12-Mar-2014 at 6:42 AM. Reason: Clarify information and typos.
Old 17-Mar-2014, 5:53 PM   #5
Kona Blue
Radio shack in my area 34222 sells the HBU22 and HBU33....... Are these antenna's I could consider also or should I stick with the HBU11K. Thanks
Old 17-Mar-2014, 5:57 PM   #6
The HBU-22 is fine. The HBU-33 would also work, though it's forward beam is a bit narrow for this application.
Old 17-Mar-2014, 6:19 PM   #7
The HBU22 is Ok for your reception situation.
Or you can also use a , ANT751 / ANT751R , Both are the same antenna.
Home Depot and Lowes may have the ANT751 / ANT751R , both are the same antenna.
Home Depot and Lowes may have the ANT751/R antenna in stock in the store , no matter what the Home Depot and Lowes web sites say.
http://www.amazon.com
http://www.antennacraft.net
Last edited by teleview; 17-Mar-2014 at 10:09 PM. Reason: Clarify information and typos.
Old 17-Mar-2014, 6:21 PM   #8
Kona Blue
This is all new to me and I am learning a lot but having said that I guess it would be best if the association lets me, to put the antenna on a roof top tripod just to get it as high as possible. And does it go without saying that a ground wire is also needed?
Old 17-Mar-2014, 6:27 PM   #9
Kona Blue
If I can not find the HBU11K in my local stores can someone suggest a Winegard model or other which is comparable that can be purchased at Best Buy.
Old 17-Mar-2014, 8:28 PM   #10
Best Buy carries the Audiovox ANT751.
Old 17-Mar-2014, 8:47 PM   #11
Your HOA may think they can tell you not to install an antenna... But the FCC says different. The FCC OTARD rule protects your right to install and use an antenna for OTA TV reception, and specifically restricts the rights of the HOA. http://www.fcc.gov/guides/over-air-r...n-devices-rule
I'd suggest that you ground your outdoor antenna mast and the coax shield. http://forum.tvfool.com/showthread.php?t=901 (see post #20 for a summary)
Re. Best Buy alternate antenna choices:
I see the Antennas Direct CS2-V and the Channel Master CM-2016 advertized on the Best Buy website...
Old 18-Mar-2014, 12:09 PM   #12
Kona Blue
Not wanting to drag this on any longer but I do appreciate the help.
I submitted a survey to Solid Xtreme Signal yesterday and they came back with a recommendation for the following 8 bay unit.
http://www.solidsignal.com/pview.asp?p=hdb8x
The unit is larger and I am not sure what the difference is in styles and or which would work better?
Comments are appreciated
Old 18-Mar-2014, 9:02 PM   #13
The UHF gain of the typical 8-bay panel antenna is more than you need. With the possible exception of the CM-4228 I would expect the VHF performance to be inadequate.
The HBU-11, HBU-22, ANT-751 and CM2016 fit your application very well, better than an 8-bay panel UHF antenna.
Old 19-Mar-2014, 1:12 PM   #14
Kona Blue
Settled....... I now know what to do and what to get. Thanks for all your help
