Old 9-Mar-2014, 11:35 PM   #1
MichaelFrank
Attic installation in Canton OH
I am considering an antenna purchase and would really like to confine it to an attic installation. While I could mount outdoors, I'd like to keep in line with the aesthetics of the neighborhood.
http://www.tvfool.com/?option=com_wr...5b945ddc26bf0c
I am interested in only the stations around the 345 degree mark (NNW from my location), up to and including WUAB (28 Real, 43.1 Virtual).
Antenna would point to the gable end of attic and need to penetrate regular black sheathing and vinyl siding.
Questions -- Is this a possibility? If so, what antenna, amplifier, etc to use?
Cable would run 50' to a two-way split, then 10' beyond that for both TVs.
Thanks for any input.
MichaelFrank is offline   Reply With Quote
Old 10-Mar-2014, 5:59 AM   #2
The Tvfool Radar Plot and Channel List of the Digital Current Plus Pending Applications Included.
The Tv stations in the Red reception zone will not be received with a antenna in the attic.
Some of the stronger signal strength Tv stations in the Yellow reception zone might be received reliably in the attic.
The Tv stations in the Green reception zone will most likely be received reliably in the attic.
If you will like to receive the Tv stations in the Red reception zone and the weaker Tv stations in the Yellow reception zone.
A LARGE antenna installed Above The Peak Of The Roof is Required.
I recommend , http://www.antennacraft.net.
HBU55 antenna.
