Old 2-Mar-2014, 4:24 PM   #1
crewchief97
Antenna type in Southern Illinois
Like a growing number of people I have finally ditched the dish. I have searched for an outdoor antenna and am more confused than ever. I would like to know what antenna would work without a rotator to receive most of the stations. Here is my signal analysis http://www.tvfool.com/?option=com_wr...5b942c904b21c2
Which direction would I point the antenna and can I use the existing dish cabling?
Thanks for your time and knowledge, Terry
crewchief97 is offline   Reply With Quote
Old 2-Mar-2014, 9:57 PM   #2
crewchief97
Any suggestions?
Old 3-Mar-2014, 2:29 AM   #3
A Simple reception situation.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North West , North , North East , East , South East.
Install a , Antennas Direct , DB8e antenna.
Aim 1 panel at about 60 degree magnetic compass direction.
Aim the other panel at about 312 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas.
The Signal strengths are Strong , a antenna system amplifier will not be required.
Here are some places to buy antennas and ect. .
http://www.amazon.com
Some and not all Negative Effects are,
Absorbing and Blocking Tv Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
In the Tv Setup Menu.
The Tv Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Yes the satellite system coaxes can be used for the antenna system , the satellite system connection hardware such as and not limited to , multiplexers , multi-switches , couplers , splitters , amplifiers , power injectors , power supplies and etc. must be disconnected and removed.
Last edited by teleview; 3-Mar-2014 at 4:43 AM. Reason: Clarify information and typos.
Old 3-Mar-2014, 11:53 PM   #4
crewchief97
Thanks for the info Teleview
