Old 14-Feb-2014, 2:12 AM   #1
OtaInSanDiego
Getting LA stations in North County, San Diego, but no SD stations?
House in southwest area of Black Mountain Ranch. Using a ClearStream Micron XG, I can get a lot of Los Angeles stations (>90 miles away), but only 7/39 or Fox (if I re-orient the antenna) from local stations.
Has anyone else had similar reception experiences in SD? Resolution? I need to stay away from outdoor antennas.
OtaInSanDiego is offline   Reply With Quote
Old 14-Feb-2014, 2:44 AM   #2
Please make and post a Tvfool report.
Use the Exact address to make the report.
Make the antenna height above ground in the report 25 feet.
Post the report.
Of the Exact address does not work , then go to the Tvfool home page and click on , >>Start MAPS<< , enter a zip code only and then move the pointer on the map to the Exact location of reception.
Make the antenna height in the report 25 feet.
Click on the , Make Radar Map , button and post the Tvfool report.
Old 14-Feb-2014, 10:28 AM   #3
If you post your exact location TVFool plot, we can analyze your situation.
Most probably, your on a spot where there is a good signal path to the northwest while the path to the south southeast is severely impaired.
Old 14-Feb-2014, 11:38 PM   #4
OtaInSanDiego
TVFool Plot
This is the link provided by TVFool's signal analysis report.
http://www.tvfool.com/?option=com_wr...5b94d291ead4bf
The house has an unobstructed, almost 180 degree, view to the north. We have neighbors on the east/west sides of the house, and the rest of our local neighborhood is to the south. There is no severe terrain in our immediate area, but there are some hills to the west.
Thanks for taking a look.
Old 14-Feb-2014, 11:43 PM   #5
OtaInSanDiego
Current antenna height is about 2 feet
I should add that reception of the LA stations is with the Micron XG located downstairs, so the height is about 2'. The generated report was for an antenna height of 15' (anticipate putting the antenna upstairs), but I did not notice any significant differences in the reports.
Old 15-Feb-2014, 12:09 AM   #6
OtaInSanDiego
My prior reply with the link didn't seem to post. Round #2...
http://www.tvfool.com/?option=com_wr...5b94d650522268
Old 15-Feb-2014, 12:12 AM   #7
OtaInSanDiego
Additional info...
You are correct about signal path. House has almost a 180 degree unobstructed view to the north.
There are houses immediately on the east and west, and a community to the south.
No "real terrain" in the immediate vicinity, but a small hill to the west.
"LA stations" are okay, but would prefer to get the local broadcasts.
Old 15-Feb-2014, 10:30 PM   #8
This Reception recommendation is based on the provided tvfool reports.
This reception recommendation is based on several recent question askers have come here with reception problems receiving , KFMB-TV Real VHF high band channel 8 CBS , and , KGTV-DT Real VHF high band channel 10 ABC.
And the continuing reception situations/problems receiving the San Diego Tv Stations.
And the Fact that the Federal Antenna Law says Yes you can install Tv antennas above the roof so as to have reliable reception.
Above the Peak of the Roof install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
Aim 1 panel at about 145 degree magnetic compass direction.
Aim the 2nd panel at about 175 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas.
For reception of the reported problems of reception of , KFMB and KGTV.
Install a , Antenna Craft , Y10-7-13 , VHF high band channel 7 thru 13 antenna.
Aim the , Y10-7-13 antenna at about , 193 degree magnetic compass direction.
Install a , Antenna Craft , 10G221 preamplifier.
Connect the DB8e antenna to the UHF connection of the preamp.
Connect the Y10-7-13 antenna to the VHF connection of the preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Home Depot and Lowes have , 10 feet Top Rail , chain link fence pipe that make good antenna mast. The cost is low dollars.
Install the , Y10-7-13 antenna below the DB8e antenna on the same mast
Separate the Y10-7-13 and the DB8e antennas by about 3 feet on the same mast.
http://www.antennacraft.net.
Digital Tv Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
Old 16-Feb-2014, 4:49 PM   #9
OtaInSanDiego
Additional Chennel Reception Information...
Desired stations...
KFMB-TV (8), KGTV (10.1), KSWB (69.1), KUSI-DT (51.1), KPBS-DT(15.1), KNSD-DT (39.1), XETV (6)
Channels rcvd with Micron XG, no amplifier (varying directional orientation)
KNSD-DT (39.1), KSWB (69.1)
With the Micron XG and amplifier (varying directional orientation)
KSWB (69.1) [intermittent], KCBS-TV (2.1), KNBC-DT (4.1), ION (30.1), KTLA-DT (5.1), KOCE-DT (50.1), KLCS (58.1) KWHY-DT (22.1), and a handful of Spanish-language stations.
Old 16-Feb-2014, 7:04 PM   #10
Have your tried putting the antenna in front of a south-facing window?
Much construction in southern California uses stucco as an exterior surface. Unfortunately, stucco has a wire mesh backing at effectively blocks radio signals. Additionally, much of newer construction also uses radiant barrier foil which does the same thing.
Give the antennas placement as much favor as you can and see what you can do.
Please run new reports at 30' and at 50'. While likely not practical for installation, those reports allow us to better visualize terrain impairments on your signal path.
Old 16-Feb-2014, 9:35 PM   #11
OtaInSanDiego
Re: South-facing windows and analysis @ 50'
Here is the analysis with the antenna height set to 50'
http://www.tvfool.com/?option=com_wr...5b94da47385d25
South-facing windows are pretty much a non-starter, given the house's floor-plan and orientation on the lot. Best possible might be a west-facing window with a south-west exposure.
Old 16-Feb-2014, 10:43 PM   #12
So, do you have stucco or radiant barrier? If you do, then you're completely dead in the water for any indoor antenna.
You'll have to evaluate if, at a minimum, an attic location is available.
Keep in mind that, for ANY antenna to work, the signals must reach it.
black mountain ranch, indoor antenna, san diego
