Old 13-Feb-2014, 11:09 AM   #1
noland77
Help in Fort Garland, Co
I need help in Fort Garland Co area in finding equipment and stations to aim for. Just moving into area (SCDR) and only 1 grainy analog (Ch 39) so far. What do I need to pull in Pueblo, Co Springs, maybe even Denver?? Maybe it would be more realistic to aim for New Mexico. Our zip ia 81133. Mountain ranges all around us,but I need help and direction/suggestions as I dont know where to start
noland77 is offline   Reply With Quote
Old 13-Feb-2014, 2:38 PM   #2
Start with making and posting a Tvfool report for the reception location.
Go to the Tvfool home page and click on , >>Start MAPS<< ,
Use the Exact address to make the report.
Make the antenna height in the report 25 feet above ground.
Also make and post 2 more reports with antenna heights of 40 and 60 feet antenna heights above ground.
If the Exact address does not work to make the report.
Then use the zip code as a starting place , and move the pointer on the map to the Exact reception location and make and post the reports with antenna heights of , 25 , 40 , 60 , feet antenna heights above ground.
Old 18-Feb-2014, 10:39 PM   #3
noland77
Thanks. Based on the way it looks, what antenna would you recommend for that area? Anyone, what antenna. We don't live up there full time, so we wont have a lot of time to try out different antennas, we need someone's best starting point, hopefully from the area that could save us a few steps. I will never realistically get the antenna 60 ft off the ground. Maybe 20, realistically 10 to 15 but we are at 8500 ft elevation or about 1000 ft above the valley that surrounds us. Please recommend a good antenna that will give us the most bang for the buck even if it takes a few extra feet of cable
Old 19-Feb-2014, 12:45 AM   #4
You need to post the link to your report so we can see the situation. Mark the location as precisely as possible.
Old 19-Feb-2014, 1:32 AM   #5
noland77
Hope this is the link you are referring to
http://www.tvfool.com/?option=com_wr...V-D%26type%3dD
I need help understanding all of this.
Old 19-Feb-2014, 1:37 AM   #6
noland77
My address is (redacted by moderator to protect the OP's privacy), Fort Garland Co, 81133 located in the Sangre De Cristo Ranches. Off of Hwy 159 off of Hwy 160 in between Fort Garland And San Luis n Hwy 159. The elevation is right at 8500, we face north and east, with an open South side for Solar.
___________________________________________________
Added by moderator, based on information posted by the OP:
10' TVFR: http://www.tvfool.com/?option=com_wr...5b94708d0b0d5a
25' TVFR: http://www.tvfool.com/?option=com_wr...5b94ebb7db6983
50' TVFR: http://www.tvfool.com/?option=com_wr...5b94fd129e6cab
Last edited by GroundUrMast; 19-Feb-2014 at 3:39 AM. Reason: protecting OP's privacy, adding TVFR links
Old 19-Feb-2014, 5:11 PM   #7
The Tv/s Must Channel Scan for the , ATCS-Digital Broadcast Tv Stations/Channels.
DO NOT channel scan for -Only- Analog channels.
DO NOT channel Scan for cable Tv channels.
The Repeater/Translator Tv transmitters are to the South West and West.
Here is information of the Digital Broadcast Tv Stations/Channels.
http://www.rabbitears.info/market.ph...allsign=125434
And here is some information I found about KENY-LP , UHF channel 39.
It looks like KENY is transmitting a Analog signal and has a application to transmit Digital.
http://en.wikipedia.org/wiki/List_of...One_affiliates.
http://www.livestream.com/kenytv
K32IK-D , UHF channel 32 , KTSC , PBS.
K49LW-D , UHF channel 49 , KOB , NBC and This Tv.
Are Very Weak signal strength.
And the other Digital Broadcast Tv Stations/Channels on up the channel list are Weak signal strength.
As a , Positive , the tvfool report is showing all the Tv stations as being LOS=Line Of Sight - Reception.
The receivable Digital and Analog Broadcast Tv Stations/Channels.
The Current UHF TV channels that are transmitted and received in the , USA , Canada and Mexico are , 14 thru 51.
Recommend install a UHF antenna that will have Maximum reception ability.
Install a , Antennas Direct , DB8e antenna.
Above the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building , install a , DB8e antenna aimed at about 211 degree magnetic compass direction.
For 1 or 2 Tv's connected a antenna system amplifier will most likely not be required.
Home Depot and Lowes have , TOP RAIL , chain link fence , PIPE , that works well for antenna mast/pipe. The price is Low Dollars.
The tvfool report is showing that all the receivable Tv channels are , ATSC-Digital Broadcast Tv Stations/Channels.
Except for 2 Analog Broadcast Tv Stations , KENY UHF channel 39.
And K51DM channel 51 , SON LIFE , a religion network.
As you can see , the Tvfool Digital Current Plus Pending Applications Included Tvfool Radar Report and Channel List shows all of the receivable Tv stations in 1 direction South West , except for KENY channel 39 , that is to the West at 268 degree magnetic compass direction.
If KENY is not reliably received with both reception panels of the DB8e antenna aimed at the main group of Tv stations to the South West , then aim 1 of the reception panels of the DB8e antenna more in the direction of KENY.
Last edited by teleview; 27-Aug-2014 at 1:55 AM. Reason: Clarify information and typos.
Old 26-Aug-2014, 1:52 PM   #8
noland77
Fort garland tv
I am in the San Ranches and I put up a deepfringe antenna with an amplifier and I pick up 19 channels. Most from new Mexico but get 11 from Co springs. Works great. I have it at 30 ft.
Old 26-Aug-2014, 2:55 PM   #9
What is the antenna make and model number.
What is the amplifier make and model number.
Old 26-Aug-2014, 6:17 PM   #10
tomfoolery
If you don't mind, what's the make and model of the antenna and amplifier?
