Old 10-Feb-2014, 5:13 AM   #1
Millercd
Help selecting antenna
http://www.tvfool.com/?option=com_wr...5b94f954c52e1d
Here is the link for my location. I would like some recommendations for an antenna that should receive all the major networks. Thanks in advance your help is appreciated.
Millercd is offline   Reply With Quote
Old 10-Feb-2014, 10:45 AM   #2
StephanieS
Greetings Millercd,
Your plot features high-VHF (real channels 7-13) and UHF (real channels 14 and up) stations.
If I were attempting to receive the majority of Seattle broadcasts, I'd choose an Antennacraft HBU33 orientated to magnetic 170 for testing purposes. http://www.solidsignal.com/pview.asp...sku=1607900500 Perform TV tuner scan once system is hooked up.
It is also suggested you install the antenna outdoors mounted on your roof with the clearest pathway to the south.
How many TVs do you want to feed? What is your length of coax run going to be? If you are planning more than two feeds way may need to discuss a distribution amplifier.
Cheers.
Old 10-Feb-2014, 2:31 PM   #3
Millercd
The install would be on the roof about 21' from grade. Only feeding one tv with abou 70 ' of coax run.
Old 10-Feb-2014, 4:04 PM   #4
Above the Peak of the Roof install a , www.antennacraft.net , HBU44 antenna with a , Antenna Craft 10G201 preamplifier aimed at about 170 degree magnetic compass direction.
Buy the , HFS-2D , 2 way splitter at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com909911.html
www.ronard.com/Tripods%200703/4712.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com
Multi-Path Reflection Tv Signals Bouncing All Around.
The Best Practice is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Some Digital Tv's will Automatic by Default channel scan to cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels~ .
Channel scan for the , ATSC-Digital Broadcast Tv Channels.
Old 10-Feb-2014, 5:49 PM   #5
StephanieS
Alright.
70' into one TV isn't bad. A preamp isn't recommended.
How is your line of sight to the south?
You should pick up multiple versions of KCPQ FOX. In addition to primary broadcast on RF 13, you should see K29ED-D which rebroadcasts KZJO and KCPQ. Possibly the same for KIRO CBS. K17IZ-D retransmits KIRO for Everett. Even though RF 17 is a little out of your beam, you may see it addition to KIRO's main feed on RF 39.
It's similar to what I have with KXLY. They have multiple broadcasts in the market. I have deleted out all the instances of KXLY out of my channel line up except the one signal that is strongest and most reliable.
Best of luck.
