Old 8-Feb-2014, 6:57 AM   #1
cinemative
Need outdoor antenna advice in Whatcom County, Northwest Washington State
Hello everyone,
I'm hoping I can get some advice on how to get the best over the air reception in my area of Northwest Washington. I live in the city of Lynden, and my house is just a couple of miles south of the Canadian border. My house is a single story and I have a few tall trees in my back yard, including a cedar that is probably over 100 feet. Although I would prefer to mount an antenna on my roof, I would be willing to run some cable and a mount up into one of my trees if it would be worthwhile.
I don't really understand the technology involved, so conversations about UHF, VHF, and such is all Greek to me.
I've currently got 2 indoor antennas that I've connected to my TV. One is a small powered device with a figure-8 metal antenna attached to a center mount that can be rotated horizontally for better signal reception. I found this at a local thrift store for around $5. If I use it in the house and aim the antenna towards Vancouver, British Columbia... I can get a channel or two but not with very strong signals. If I attach a longer cable and move it outside, the signal is much better and I can get 8 or 9 channels. Leaving this device outside in the northwest weather isn't an option, so I've moved it up to the northwest corner of my attic and mounted it onto a platform. Signals are better than inside the house, but worse than outside. I get about 6 or 7 channels, and sometimes they are good, and sometimes they cut in and out.
The other antenna is one I bought from Costco a couple of weeks ago, and it's the flat panel type that you stick to a window. As far as I can tell after some testing, it works more or less as well (or bad) as my cheapo thrift store antenna.
The channels I can get are all Canadian, and I'm slowly figuring out which American networks they periodically broadcast... so I can get FOX, CBS, and ABC shows once in a while. Thankfully, they broadcast the Seahawks victory in the Super Bowl, but it was all Canadian ads... so that was a little bit of a bummer, but for free I guess I can't complain.
At this point, I'm ready to return the Costco antenna and ditch the thrift store one for something I can mount to the roof. I'm willing to spend $100+ if necessary, but only if I can be assured by someone that my investment will result in more channels and consitently stronger signals.
In doing a bit of online research, I've found antennas with 4/5 star reviews ranging in price from $25 to $75. I was just about to order one from Amazon.com (since I have free Prime shipping), but I found the TVFool forums and discovered that people with antenna knowledge were not fans of those antennas...
So there you have it. That's how I arrived here, on the TV Fool forums, and now I'm hoping to get some advice on what to do next.
WHAT I WANT:
  • I can live with the Canadian stations, since their towers are much closer and they broadcast a few of the shows I want to watch.
  • I would prefer to pick up the Seattle stations, but since I'm about 100 miles north I don't have much hope that I'll be able to get a signal.
Here's my report:
http://www.tvfool.com/?option=com_wr...5b9483a74f763a
QUESTIONS:
1. Will I need more than 1 antenna if I need to pick up stations in Canada (north) and the US (south), or is there a type of antenna that can receive signals from multiple directions?
2. If the answer to question #1 is NO, then do I need to find an antenna with a remote controlled rotating motor so I can move the antenna in order to tune certain channels?
Any help is greatly appreciated!
Thanks,
Harold in Lynden, WA.
cinemative is offline   Reply With Quote
antenna, lynden, northwest washington, reception, whatcom county
