Old 7-Feb-2014, 12:05 AM   #1
scotticus
Reception help in Boerne, TX
so here is my report:
http://www.tvfool.com/?option=com_wr...5b94dd2ad0fe71
i've been a cord cutter for around 2 years, all my tv comes from the internet. I'd like to receive sports on local broadcast.
I assume with my distance from the San Antonio TV station towers, i'm going to probably need a large amplified antenna. Don't really know what to get as far as that goes. My major problem is that my house is a single story house, shadowed by the one next door, which is two story. Mounting a tripod on my roof would require a very tall mast, and the front part of the house is the only area available. I've actually asked my HOA to allow me to put up a small tower in the very back of my yard (it backs up to a drainage greenway) so that I can mount the TV antenna on that. I don't expect they'll accept it, but I sort of told them it was that or the front of the house and cited the OTARD rule, nicely.
Guess what i really need to know is what i'm going to need to receive the normal stations (KSAT, KLRN, KABB, KENS, and WOAI). The tower i proposed was 20ft with a mast, so i could get the antenna almost 30' up if that goes through. My house has a feed for 2 TVs, and that is probably all I will need to send the signal to.
scotticus is offline   Reply With Quote
Old 7-Feb-2014, 3:07 AM   #2
For Reliable reception install a , www.antennacrft.net , HBU44 antenna aimed at about 150 degree magnetic compass direction.
Install a , RCA , TVPRAMP1R preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com
www.ronard.com/909911.html
www.ronard.com/Tripods%200703/4712.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
As Always , trees and tree leaves , plants and plant leaves have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Multi-Path Reflecting Tv signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
The directions of reception are , South West , West South West , East.
Old 8-Feb-2014, 10:30 PM   #3
scotticus
I was able to get an HBU33 and a RadioShack amplifier working very well. Only 16' up on my test but i was able to get all the channels i wanted. Thanks.
Old 10-Feb-2014, 3:26 PM   #4
Very good , and you know what to do if better reception is required.
