Old 6-Feb-2014, 11:56 PM   #1
Free1
Lightbulb Antenna Recommendation for OTA first timer in Hillsboro OR
For several years, have not been able to afford cable. Want to get OTA TV channels. I am new to setting up OTA TV and need your advise. From what I have seen, this forum has very knowledgeable experts, that help provide valuable insights and recommendations.
Channels most interested in (7-50): PBS, NBC, Fox, CBS, ABC. Any additional channels would be bonus.
http://www.tvfool.com/?option=com_wr...5b94264ac2067e
We only need 1 TV setup for OTA. One other thing, I do live up a hill and have tall pine trees. I can put roof top antenna on house.
What antenna would you recommend for best reception? What channels are possible via OTA and good antenna?
Your help appreciated,
Free1 is offline   Reply With Quote
Old 7-Feb-2014, 4:17 PM   #2
Free1
Here is TV Fool screen:
Old 7-Feb-2014, 4:44 PM   #3
Sharing the link is adequate, it has the needed information.
Old 7-Feb-2014, 9:29 PM   #4
For reception of the weaker signal strength Digital Broadcast Tv Stations /Channels to the North East and stronger signal strength Digital Broadcast Tv Stations/Channels to the South.
With 1 antenna aimed in 1 direction and no antenna rotation with a antenna rotator.
Install a , www.antennacraft.net , HD1800 All channel antenna aimed at about 47 degree magnetic compass direction.
Here are some Above the Peak of the Roof antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com.
Home Depot and Lowes have , Top Rail , chain link fence Pipe that makes a good antenna mast , the price is low dollars.
Install a , RCA TVPRAMP1R , preamplifier.
www.amazon.com
Buy the , HFS-2D , 2 way splitter at , www.hollandelectronics.com , or , www.amazon.com
The Best Practice is to install the HD1800 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Old 8-Feb-2014, 11:20 AM   #5
StephanieS
Greetings Free1,
Edit: If you are in Hillsboro, can you rerun your TV fool plots at 50', 75' and what you consider the height of your trees? I ran a generic plot off your zipcode and it reports Line of sight conditions to Portland transmissions.
I want to see if elevation improves your conditions dramatically. If so, you can go higher with a tree mounted antenna that is smaller than the monster HD1800. However, let's see what your reposting says.
SS
Old 8-Feb-2014, 7:46 PM   #6
Free1
Greetings,
Here is 50' TVF
http://www.tvfool.com/?option=com_wr...5b94461e09a4e9
Here is 75' TVF
http://www.tvfool.com/?option=com_wr...5b9461132d5fad
Majority of the channels of most interest are digital High VHF and UHF (do not need low VHF channels). Looks like the direction between 45-47 degree has the majority of channels of interest. So am I correct to assume a good UHF/Hi VHF directional antenna is needed.
I would like to get the best highest quality antenna. Form research, these models get good reviews.
A) Winegard HD8200U (Yagi, Hi VHF/UHF, Gain Hi VHF 12.6, UHF 14.2)
B) Channel Master CM4228HD (Bowtie, Hi VHF/UHF, Gain Hi VHF ___, UHF 12)
Which antenna is better, if TV towers are on the other side of our hill?
Thanks,
Old 8-Feb-2014, 11:17 PM   #7
Free1
Greetings,
Here is 50' TVF
Here is 75' TVF
Majority of the channels of most interest are High VHF and UHF. Looks like the direction between 45-47 magnetic, has the majority of channels of interest. So am I correct to assume a UHF/Hi VHF directional antenna is needed.
I would like to get the best highest quality antenna. Form some research, these models get good reviews.
I was leaning toward the Winegard HD8200U. What do you think about these antenna's? Which one will be better, there is a hill between TV towers and house?
Thanks,
antenna, ota, reception, recommendations
