Old 3-Feb-2014, 10:20 PM   #1
MattZuke
New Antenna - University Place, WA
http://www.tvfool.com/?option=com_wr...5b94efb168b7a2
Still installing the last antennas for the GF, so I might as well get one myself.
I'm going to presume the same recommendation would apply? The DB8e with a Y10 7-13?
The Priority is ABC(38), NBC (48), CBS(39), Fox(13), CW(7), PBS(9).
MattZuke is offline   Reply With Quote
Old 4-Feb-2014, 1:37 AM   #2
The DB8e & Y10713 look like a very good option.
Old 4-Feb-2014, 6:53 AM   #3
Aim 1 panel of the DB8e , UHF channels 14 thru 51 , antenna at about 10 degree magnetic compass direction.
Aim the other panel of the , DB8e antenna at about 326 degree magnetic compass direction.
Aim the , Y10-7-13 VHF high band channels 7 thru 13 antenna at about 345 degree magnetic compass direction.
Most Digital Broadcast Tuners have a , Signal Strength Meter and some Digital Broadcast Tuners all so have a , Signal Quality Meter .
Signal Quality is Important.
As Always , the antenna aim direction and location of antenna can be adjusted for best reception.
