Old 30-Jan-2014, 5:06 PM   #1
tfbrown60
Looking for antenna help Hurricane,WV
http://www.tvfool.com/?option=com_wr...5b940e78b9c080
I am canceling my Direct TV , I currently have a small Terk antenna that is attached to the dish with thumbscrews and is powered by the DTV receivers. I would like to remove the dish and attach a new antenna to the dish mount and use the existing coax to two TVs. The antenna I have now will receive everything I want but WSAZ the NBC station can be spotty. So I am looking for advice on a new antenna.
tfbrown60 is offline   Reply With Quote
Old 31-Jan-2014, 4:25 PM   #2
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , West West North , East South East.
Install a , www.antennacraft.net , HBU11K antenna , aimed at about 295 degree magnetic compass direction.
No antenna system amplifier is required.
For 1 Tv connected , use No splitter.
For 3 Tv' connected use a simple common 3 way splitter.
www.amazon.com
http://www.summitsource.com.
To Prove Reception
Connect a NEW Continues length of coax to the HBU11K antenna and run the NEW Continues length of coax through a open door or window , direct to 1 Tv.
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
The Best Pratice is to install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Last edited by teleview; 26-Mar-2014 at 2:26 PM. Reason: Clarify information and typos.
Old 1-Feb-2014, 12:06 AM   #3
tfbrown60
Thank you for your reply, solidsignal recommended the Wineguard MS2002 Metrostar. I am researching and waiting for the weather to cooperate before I get on the roof.
Old 1-Feb-2014, 12:24 AM   #4
For a long time , a real long time , solidsignal was the first recommendation for antennas and etc. .
Because of repeated reports of less then correct antenna and other recommendations I have stopped recommending solidsignal.
Last edited by teleview; 26-Mar-2014 at 2:40 AM. Reason: Clarify information and typos.
Old 26-Mar-2014, 1:23 AM   #5
tfbrown60
I have ordered the HBU11K , I will be connecting two TV's . One is connected to a two tuner tivo HD and the other to a four tuner tivo roamio . With a total of six tuners will I need some sort of amplifier?
Old 26-Mar-2014, 2:48 AM   #6
Splitters reduce signal strength , when a split takes place signal strength is reduced.
Tuners in and of and by them selfs have little effect on signal strength.
Old 26-Mar-2014, 2:49 AM   #7
If you are only splitting two ways to feed the two chassis, no, try without any amplification.
If you have to split 6-ways, then maybe. But try it 'bare-foot' first.
Old 24-Mar-2015, 5:18 PM   #8
lrkuta
Did you try the Winegard MS-2002 Metrostar antenna? How did it do? Thank You.
lrkuta is offline   Reply With Quote
Old 24-Mar-2015, 5:39 PM   #9
tfbrown60
I did not try the Wineguard , I used the HBU11K that was recomended . Works good after getting it aimed properly. I get the 4 networks plus ION , CW , and PBS .
Old 24-Mar-2015, 6:17 PM   #10
lrkuta
What direction did you point your antenna?
Old 24-Mar-2015, 6:42 PM   #11
tfbrown60
295 deg then tweaked a. little , just like teleview recommended . Fox and ABC are aprox 180 deg from the others so I tried to aim the backside towards them .
