Above The Peak Of The Roof install a ,
www.antennacraft.net , HBU44
Antenna aimed at about 300 degree magnetic compass direction.
Here is how to aim antennas ,
www.kyes.com/antenna/pointing/pointing.html
Install a ,
www.channelmasterstore.com , CM7778 preamplifier.
Buy the , HFS-2D or HFS-3D , splitters at ,
www.hollandelectronics.com , or ,
www.amazon.com
Here are some Above the Roof antenna mounts.
www.ronard.com/909911.html.
www.ronard.com/ychim.com
Buy the , ronard antenna mounts at ,
www.ronard.com , or ,
www.amazon.com .
As Always , trees and tree leaves , plants and plant leaves have a Negative Effect on Broadcast Tv Reception and so buildings and and other obstructions including your own roof and building in the directions of reception.
Multi-Path Reception Tv signals bouncing allaround .
The Best practice is to install the , HBU 11k , at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and building.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the , Antenna Channels ~ DTV Antenna Channels, ATSC-Antenna Channels ~ Air Channels~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ ATSC-Anetnna Channels ~ DTV Channels ~ Air Channels~.
The Tv Must Channel Scan for the ~ ATSC-Digital Broadcast Tv Stations/Channels.
