Old 20-Jan-2014, 6:51 PM   #1
Curt
DB8e reception
Installed a DB8e on the roof and could get channels 14.1, 12.1, 50.1 that seems like all the latino channels but not ABC, CBS, FOX. Those channels had a lower db than ABC or CBS and were coming from the same direction. Don't have any idea, when I mapped it on tvfool local channels should be easy to get.
http://www.tvfool.com/?option=com_wr...5b94155bfe7670
Curt is offline   Reply With Quote
Old 20-Jan-2014, 8:43 PM   #2
Please call customer service at 877-825-5572. Hours are from 9-9 Central.
There's way too much information absent from your posting and it's simply easier to speak to one of our representatives to troubleshoot your reception concerns.
Old 21-Jan-2014, 12:45 AM   #3
The Digital Tv Reception Signal Strengths Are Very Weak Signal Strengths at Your Recetion Location.
Install the DB8e antenna Above The Peak Of The Roof.
Aim both panels of the DB8e antenna at about 300 degree magnetic compass direction.
Use a Real and Actual magnetic compas to aim antennas.
Also install a , www.antennacraft.net , Y10-7-13 VHF high band channels 7 thru 13 antenna aimed at about 300 degree magnetic compass direction.
Install a , RCA , TVPRAMP1R , preamplifier.
Connect the DB8e UHF Channels 14 thru 51 antenna to the UHF connection of the preamplifier.
Connect the Y10-7-13 antenna to the VHF connection of the preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com .
www.amazon.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ .
Scan for , ATSC-Digital Broadcast Tv Stations Channels.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building on the directions of reception.
The Best Pratice is to install the antennas at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof at house.
Old 21-Jan-2014, 3:20 AM   #4
I can vouch for Antennas Directs' commitment to caring for their customers. Please give them the opportunity to help you directly.
