Old 20-Jan-2014, 6:19 PM   #1
letsrollusafa11
Antenna advice / Fairfield, CA
Just looking for antenna setup advice. I currently have a DirecTV dish setup outside with all the wiring, but no service. I'm just trying to get the max number of channels possible. Not really interested in Spanish channels, but I understand picking and choosing isn't the name of the game. Thank you for the help!
http://www.tvfool.com/?option=com_wr...5b940690d8b130
letsrollusafa11 is offline   Reply With Quote
Old 21-Jan-2014, 3:16 AM   #2
The local Sacramento stations should be easy to receive. I'd use an all channel antenna such as the Antennacraft HD850 or Channel Master CM-3018. This gives you a good shot at seeing KCSO-LD which is reported to carry ME-TV in addition to Telemundo. http://en.wikipedia.org/wiki/KCSO-LD
You could build a second, separate system aimed at San Fransisco using a lager, more aggressive antenna or combination of antennas... happy to elaborate if you're interested.
Old 21-Jan-2014, 3:34 AM   #3
letsrollusafa11
Awesome, thanks! Real new to this, would I require an amplifier? The distance from the antenna to the TV isn't too bad, but would be coming from outside. I'd hopefully just attach one of these antennas to the existing DirecTV mast. I'm pretty much just interested in the major channels, so San Fran would possibly just be repeating those channels from Sac I guessing. But I'm definitely interested in any setup ideas. Thanks again!
Old 21-Jan-2014, 3:58 AM   #4
The local Sacramento signals are strong enough to advise against any amplifier on that antenna. You don't want an amplifier or tuner to be overloaded by a strong signal, that would leave you with less reliable reception.
I would expect a considerable amount of duplication of national network programing. The local news and independent signals from San Fransisco may be interesting though. If I was to go after the San Fransisco signals, I would use an Antennas Direct DB8e + Antennacraft Y10713 + an RCA TVPRAMP1R preamplifier. I'd cable the local and San Fransisco feeds separately... http://forum.tvfool.com/showthread.php?t=2882
Old 21-Jan-2014, 6:02 AM   #5
Above the Peak of the Roof install a , www.antennacraft.net , HD850 All Channel antenna aim at about , 85 degree magnetic compass direction.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Multi-Path Reflections Bouncing All Around.
The Best Pratice is to install the HD850 antenna at a location that has the least amount to no amount of obstructions of any type or kind on the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ .
Scan for , ATSC-Digital Broadcast Tv Stations/Channels.
