Old 13-Jan-2014, 12:28 PM   #1
shaunz
Need some advice
I have been doing some research on getting rid of satellite and going with an antenna. Based on my report, it looks like I should have no problem picking up my local channels. But choosing an antenna can certainly get confusing and difficult for those that don't understand all the info on the reports. I was looking at either the RCA ANT751 or one of the 4 bay bowtie antennas like the Antennas Direct DB4E. Mount location would be on my roof. Any suggestions??? Do I need a preamp? Looking to split this feed to go to 2 TVs. Thanks in advance.
http://www.tvfool.com/?option=com_wr...5b94b29f6ae4ef
shaunz is offline   Reply With Quote
Old 13-Jan-2014, 3:05 PM   #2
A Simple Reception situation.
For reception of the Local Digital Broadcast Tv Stations/Channels.
HBU11K antenna Above The Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North East , South , South West.
Aim the HBU11K antenna at about , 190 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
A antenna system amplifier will most likely not be required.
http://www.amazon.com.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing , Blocking , Reception.
The Best Practice is to install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
And Do Not channel scan for only , Analog Tv channels.
Go into the Digital Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
Old 13-Jan-2014, 5:55 PM   #3
I'm very impressed with my DB4e, but it's a UHF only antenna, intended to cover real channels 14 through 51.
The ANT-751 and televiews suggestion of the HBU-11 fit your application far better because they have coverage for real channels 7 through 51.
The Antennas Direct C2V is yet another option that fits your situation.
Old 13-Jan-2014, 8:53 PM   #4
shaunz
is there a big difference between the ANT 751 and HBU11K. The look to be the same to me.
Old 13-Jan-2014, 9:23 PM   #5
The Bowtie shaped UHF channels 14 thru 51 metal reception element.
Gives the HBU11 a slight reception advantage over the ANT751.
Old 31-Jan-2014, 9:26 PM   #6
shaunz
Ok, my HBU11K was delivered today. I went ahead and assembled it but had some questions on pointing it. Above, it was stated that I should aim it at 190 degrees. I'm a little confused on this as my more critical channels seem to be in the other direction. My main channels that I am concerned about are CBS, FOX, and NBC. What heading should I point the antenna in for those 3 channels based on my report.
Old 31-Jan-2014, 9:47 PM   #7
Yes I see.
Aim the HBU11K antenna at about 50 degrees magnetic compass direction.
