Old 8-Jan-2014, 2:12 AM   #1
Sjschmidtky
Novice Question: Front or Back
So, I installed a Channel Master 4228HD in my attic with good results and pointed it in the direction of most channels. My stupid question... Is there a front and a back to the antenna? I assumed the side with the attached cross wires was the front. Does it matter?
Thanks, Steve
Sjschmidtky is offline   Reply With Quote
Old 8-Jan-2014, 2:47 AM   #2
Flint Ridge
Junior Member Wannabe
The side with all the whiskers is the front.
Yes it can make a difference on weak signals. It is technically a directional antenna and as such is designed for frontal gain and actually rejection to the rear.
Are you getting the channels you wanted?
Old 8-Jan-2014, 3:01 AM   #3
The >< shaped metal wires are the receiving wires.
This is the front of the antenna.
The metal rods behind the wires , are the reflectors , that reflect more signal to the >< shaped metal receiving wires , then the >< shaped metal receiving wires , can receive without a reflector.
The metal reflector rods will reduce and block signal that arrives at the back of the antenna.
___________________
To prove that the metal reflector rods will reflect Tv signals away from the >< shaped metal wires.
Aim the Back of the antenna at a Weak Signal Strength Tv Station/Channel.
Now aim the Front of the antenna at the Weak Signal Strength Tv Station/Channel.
If you will like to prove that the metal reflector rods are providing more signal to the >< shaped metal reception wires at the Front of the antenna.
Then remove the metal reflector rods , so that only the >< shaped metal reception wires are receiving the Weak Signal Strength Tv Station/Channel.
Old 8-Jan-2014, 4:09 AM   #4
Sjschmidtky
Yes, I'm getting the signals and have the whiskers pointed front ways. Just wanted to make sure I'm maximizing my number of signals. I enjoyed calling my cable provider today and canceling my paid service in favor of free service!
