Old 5-Jan-2014, 3:21 PM   #1
Ware
Question Signal Analysis/Equipment Recommendation - Please Help
http://www.tvfool.com/?option=com_wr...5b949199459278
I do not have an antenna now, so I'm both new here and new at this. If OTA is feasible for my location, I want to make sure I select the right equipment.
Attic is the best that I can do - I can't hang anything outside my home.
Thank you for your time.
Ware is offline   Reply With Quote
Old 5-Jan-2014, 6:01 PM   #2
Limiting yourself to an attic installation is going to result in less reception of available signals. It's a bit like buying an expensive camera and then trying to take pictures through dirty window glass, and in some cases, with the shades pulled and shutters closed.
If we were neighbors, you'd see a chimney, eve or tripod mounted 10' mast on my roof. I'd opt for a large combo antenna such as the Winegard HD7698P or Antennacraft HBU-54 or HBU-55.
Depending on the results I got, you may see me add a second antenna aimed at a second group of signals.
Old 6-Jan-2014, 7:04 AM   #3
The ATSC-Digital Broadcast Tv stations/channels that are required to receive are 2 directions, South West and North East.
Install a , Antennas Direct DB8e UHF channels antenna.
The DB8e UHF antenna has 2 , 4 bay bowtie panels that can be aimed in any direction.
Install the DB8e Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South West and North East.
Aim 1 panel at about 230 degree magnetic compass direction.
Aim the 2nd panel at about 21 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas.
For reception of KAFT , REAL VHF high band channel 9 PBS install a , Antenna Craft Y5-7-13 antenna , aimed at about 27 degree magnetic compass direction.
Install a , RCA , TVPRAMAP1R , preamplifier.
And connect the DB8e UHF antenna to the UHF connection of the preamp.
And connect the Y5-7-13 VHF antenna to the VHF connection of the preamp.
The , RCA preamplifier can be connected in the single input combined mode or can be connected in the separate UHF/VHF antenna mode.
Use the Separate UHF/VHF antenna mode.
Buy the , HFS-2D and HFS-3D and HFS-4D , splitters at , http://www.solidsignal.com , or , http://www.hollanelectronics.com.
Buy the ronard antenna mounts at , http://www.soldsignal.com , or , http://www.ronard.com.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.antennacraft.net.
The Best Practice is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 9-Jan-2014 at 4:09 PM. Reason: Clarify information and typos.
