Old 1-Dec-2013, 4:30 PM   #1
RCBOB
Info for CM QUANTUM 1165A??
I have this antenna idle on the roof, I believe its a 1165A. Been up there for at least 15 years, had no luck getting the Phoenix stations with Squaw Peak in the way. Now with digital signals is it a good antenna to search OTA signals?
In the photo it shows a rotator, ant.still has the 300 ohm line attach. Don't know if the rotator still works.
In the house I will only feed one TV. Will need a switch to OTA and back to DISH. Not ready to dump DISH if the OTA fails.
Any ideas will be appreciated.
http://www.tvfool.com/?option=com_wr...46aeda2482c991
RCBOB is offline   Reply With Quote
Old 1-Dec-2013, 6:48 PM   #2
Remove and discard the old antenna and rotor and All 300 ohm twin lead.
Many Digital Broadcast Tv stations/channels will be received.
Install a , www.antennacraft.net , HBU33 antenna aimed at about 170 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html .
To Prove Reception , connect a NEW Continues Length of RG6 coax with the Compression type connectors on the ends of the coax to the antennas matching transformer (balun) , and run the NEW Continues Length of coax through a open door or window direct to 1 Digital Tv.
The Digital Tv Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv stations/channels.
Often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ , in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
At this Prove Reception stage , install no antenna system amplifier.
