Old 29-Nov-2013, 10:33 PM   #1
FLAlleycat
Antenna recommendations (Orlando)
Here's my home info in Orlando: Would appreciate info on antennas, indoor/attic/roof top and where to aim it. House stucco with paper/foam insulation. Thanks so much!!
http://www.tvfool.com/?option=com_wr...46ae92eefb5e37
FLAlleycat is offline   Reply With Quote
Old 29-Nov-2013, 11:51 PM   #2
Nice report...
Point an RCA ANT-751 eastward. You'll do best with the antenna outside clear of obstructions such as trees and buildings.
Old 30-Nov-2013, 12:48 AM   #3
A Super Simple reception situation.
Install a , www.antennacraft.net , HBU-11 above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in all directions and Many Digital Broadcast Tv stations/channels will be received.
Aim the HBU-11 at about 90 degree magnetic compass direction.
The Tv signals are very strong , a antenna system amplifier is not required.
www.solidsignal.com
www.amazon.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations:channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Air Channels ~ Air Channels ~ Antenna Channels ~.
Scan for channels.
