Old 16-Nov-2013, 3:13 PM   #1
rutman
reception help?
so many antenna choices. will be outdoors 20ft. high. a lot of trees. advice on reception and antenna to purchase. 2-3 TV's connected. any advice appreciated.http://www.tvfool.com/?option=com_wr...46ae1e86d4f606
rutman is offline   Reply With Quote
Old 16-Nov-2013, 9:52 PM   #2
For reception of ->Many<-Digital Broadcast Tv stations/channels and as as many as possible with 1 antenna aimed in 1 direction. And no antenna rotator.
Install a ANT751 , aka , ANT751R antenna above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , west , north west , south west , south , north , north east.
Aim the antenna at about 300 degree magnetic compass direction.
Install a Channel Master CM7778 preamplifier.
Buy the HFS splitters at , www.solidsignal.com .
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often mamed the ~ DTV Channels ~ Air Channels ~Antenna Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
Go into the Digital Tv Setup Menu and select ~DTV Channel ~ Air Channels~ Antenna Channels.
Scan for channels.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception
Some and not all of Negative Effects are
Multi-Path Reflecting Tv signals bouncing around
And so do buildings and other obstructions have a Negative Effect on reception in the directions of reception , including your own roof and building.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
Last edited by teleview; 17-Nov-2013 at 5:53 AM. Reason: Clarify information and typos.
