Old 6-Nov-2013, 4:47 PM   #1
captainggg
Looking For PBS
Thank you in advance for your help. I am receiving all green and yellow channels acceptably. I am receiving a weak signal from 15.1 (3) but not enough to form an image. The antenna is rotated to the correct direction.
http://www.tvfool.com/?option=com_wr...46ae70b09a84bf
- Winegard HD7697P antenna on roof
- Winegard LNA 200 preamp, 1.5' RG-6 from antenna to pre-amp
- Rotator
- 50' RG59 from roof to house
- LNA power mod before (2) splitters, approx 50' of cable in the house
Any advice is greatly appreciated. Greg
captainggg is offline   Reply With Quote
Old 6-Nov-2013, 11:22 PM   #2
Talking Pratical and Useful Information.
Install the antenna above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of reception.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on broadcast Tv reception and so do buildings and other obstructions including your own roof and building.
The Best Pratice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in he directions of reception including your own roof and house:
Make sure the HD7697P antenna is put together correctly.
Make sure the phasing lines (connecting wires) are connected corectly in side of the plastic box of the antenna.
Make sure the phasing lines (connecting wires) are not touching the boom of the antenna.
Make sure the phasing lines (connecting wires) are not touching each other.
Aim the antenna at about 92 degree magnetic compass direction.
Also try aiming antenna at about 29 degree magnetic compass direction. A alternate direction for WPSU PBS.
To prove reception ,
Connect a , New continues length of coax to the antenna
No amplifier , no power injector , no power supply
No splitters , No couplers , No nothing
Run the New continues length of coax through a open window or door direct to 1 Tv.
Digital Tv tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
Do Double Rescan , www.wchstv.com/DoubleReScanAlert.pdf
The Tv Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the , DTV Channels ~ Air Channels ~ Antenna Channels , in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels .
What is reception like now??
If Ok , add in all the componets of the LNA-200 'Boost' XT amplifier.
If reception is Ok then add in other components until problem is found.
Last edited by teleview; 7-Nov-2013 at 1:06 AM. Reason: Clarify information and typos.
Old 7-Nov-2013, 12:27 AM   #3
If reception of WPSU is received at the 29 degree magnetic compass direction.
Then Test reception by aiming the antenna at about 70 degree magnetic compass direction , a in between aim direction of WPSU at 29 degree and the group of Tv stations at 123 degree magnetic compass direction.
As always , the starting antenna aim direction is the ---> starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Last edited by teleview; 7-Nov-2013 at 3:33 AM. Reason: Clarify information and typos.
