Old 24-Oct-2013, 2:58 PM   #1
Wismer
Antenna Recommedation
Nice website! I've ended my dish network. I've got RG6 coax cable running to a 4 foot pole with a little dish on top of it out in the yard about 10 feet from the house. I was wanting to use it to mount an antenna. This is my signal analysis report: http://www.tvfool.com/?option=com_wr...46ae489d31bcb7 . Would the attic be better since it's higher off the ground? What antenna should I be in the market for? Any advice would certainly be appreciated.
Wismer is offline   Reply With Quote
Old 24-Oct-2013, 5:15 PM   #2
Practical and Useful Information
The Digital Broadcast Tv stations:channels are Weak Signal Strength at your reception location at the 5 foot antenna height above ground.
Please make and post 2 more tvfool radar plots and channel lists.
One at 25 feet antenna height above ground.
One at 40 feet antenna height above ground.
Do not delete the first tvfool report that is 5 feet antenna height above ground.
Last edited by teleview; 24-Oct-2013 at 5:17 PM. Reason: Clarify information and typos.
Old 24-Oct-2013, 6:40 PM   #3
Wismer
Thank you for helping me. 25ft signal analysis http://www.tvfool.com/?option=com_wr...46aef0c246d8be
40ft signal analysis http://www.tvfool.com/?option=com_wr...46ae0b21117d65
Old 24-Oct-2013, 6:44 PM   #4
Wismer
antenna recommendations
Teleview,
These are the two reports requested.
40 feet TV Signal Analysis Report: http://www.tvfool.com/?option=com_wr...46ae0b21117d65
25 feet TV Signal Analysis Report: http://www.tvfool.com/?option=com_wr...46aef0c246d8be
Old 24-Oct-2013, 11:27 PM   #5
Siganal strengths are improved at 25 feet above ground.
Install a Channel Master CM5016 antenna above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , north , north west , west , south west , south east , east , north east.
Aim the CM5016 antenna at about 265 degree magnetic compass direction.
Here is how to a antennas , www.kyes.com/antenna/pointing/pointing.html
Install a Channel Master CM7778 preamp.
Buy the HFS splitters at , www.solidsignal.com .
www.ronard.com/909911.html
Use the , ronard(911) , 5 foot tripod antenna mount .
www.ronard.com/34424560.html
Use the , ronard(4560) , eave antenna mount .
www.ronard.com/ychim.html
Buy the ronard antenna mounts at solidsignal by typing , ronard(x) , I the solidsignal search box or buy from ronard.
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.ronard.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception
Absorbing , Blocking , Tv reception
Multi-path Reflections bouncing all around
And buildings and other obstructions including your own roof and building.
The Best Pratice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , DTV channels ~ Air Channels ~ Antenna Channels , in the Tv Setup Menu because the Tv transmissions travel through the Air from transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels.
Scan for channels.
Old 25-Oct-2013, 3:01 PM   #6
Wismer
to TeleView
Thank you very much for helping me! Advice is worth so much and I can tell you gave a lot of thought to my circumstance. Much appreciated!
