Old 6-Oct-2013, 6:41 PM   #1
StanR
Best indoor and best outdoor Antenna Recommendations
Can you recommend the best indoor antenna as well as the best outdoor antenna for the following location that would get best reception and most channels?
http://www.tvfool.com/?option=com_wr...46ae39e101ed57
I was thinking that the Mohu Leaf for indoors (should I get the "Ultimate" amplified version or the regular one?) or do you suggest a different indoor antenna?
And, for outdoors, I was thinking of getting the C2 Clearstream or do you suggest a different outdoor antenna.
Thank you in advance for your suggestions and help.
Stan R.
StanR is offline   Reply With Quote
Old 6-Oct-2013, 9:40 PM   #2
The Clearstream 2V, whether indoors or outdoors, will run circles around a Leaf.
Mount is to it faces in an easterly direction for best results.
