Old 25-Sep-2013, 6:54 PM   #1
Eaglebox
Trouble receiving ABC
I have recently purchased the Antennacraft HDView360 antenna. I am able to pick up NBC, CBS, FOX, IPTV, and CW from Des Moines, which is 65 miles away. My TV fool report says I should be able to get ABC too, but I can't. Help!
http://www.tvfool.com/?option=com_wr...46ae81972b7bae
Eaglebox is offline   Reply With Quote
Old 25-Sep-2013, 8:01 PM   #2
The HDView360 would not be my antenna of choice in the situation you face.
I would consider antennas such as the Antennacraft HD1850, Channel Master CM-3671 and Winegard HD7084P. These larger antennas would give you a decent chance at reception of a Low-VHF signal such as WOI, real CH-5.
Old 25-Sep-2013, 9:53 PM   #3
The Current Broadcast Tv stations channels that are transmitted and received in the , USA , Canada , Mexico , are ,
UHF band channels 14 thru 51.
Your location has receivable broadcast Tv channels in All 3 Tv Bands.
The reception signal strengths of the Tv stations/channels at your location are , Low Signal Strengths and far away 65 plus + miles.
Install a Large ALL Channel Broadcast Tv Antenna above the roof in such a manner that the roof and building are not impeding and obstructing and blocking reception in the direction of , East.
Install a Winegard HD7084P antenna aimed at about 104 degree magnetic compass direction.
_____
Install a Winegard , LNA-200 'Boost' XT amplifier.
_____
Buy the HFS splitters at , http://www.saolidsignal.com.
______
Here are some strong and sturdy antenna mounts.
Use the (ronard911) 5 foot tripod antenna mount.
Use the (ronard 4560) eave antenna mount.
Buy the ronard antenna mounts at , http://www.solidsignal.com or buy from http://www.ronard.com.
_________
http://www.solidsignal.com.
http://www.amazon.com.
______
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast Tv reception and so do buildings and other obstructions in the directions of reception including your own roof and house.
The Best Practice is to install a antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
______
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.wchstv.com/DoubleReScanAlert.pdf.
Old 25-Sep-2013, 10:38 PM   #4
Eaglebox
Thanks. I will just have to deal with no ABC. I am in an apartment, so those other antennas won't work for me (can't mount anything). The HDView 360 is good for me because I can just set it on the balcony. Oh well.
