Old 18-Sep-2013, 2:06 AM   #1
AwesomeQ2
Help!
I can only get 2 DTV channels. 24.1 and 24.2. Any help would be greatly appreciated. Thanks!
http://www.tvfool.com/?option=com_wr...46aed178c9ce27
AwesomeQ2 is offline   Reply With Quote
Old 18-Sep-2013, 2:14 AM   #2
Based on the path profile of the signals from the NE, there's a significant hill or small mountain in the way of your view of those transmitter antennas. (Example: http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d8 )
I would be mounting an Antennas Direct 91XG on my roof if I was in your situation. I'd also use an RCA TVPRAMP1R preamp.
Old 20-Sep-2013, 12:35 AM   #3
Above the roof in such a manner that the roof and building are not impeding and blocking reception to the , North East , East , install a Channel Master CM4228HD antenna aimed at about 57 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
__________
A Winegard DS3000 J pole type antenna mount works Ok with the CM4228HD antenna.
__________
Install a Winegard , LNA-100 'Boost' amplifier.
__________
http://www.solidsignal.com.
http://www.amazon.com.
___________
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ 'Antenna Channels' in the Digital Tv Setup Menu.
Go into the Digital Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 23-Sep-2013 at 8:40 PM. Reason: Clarify information and typos.
