Old 15-Feb-2011, 1:59 AM   #1
saintbaud
Antenna for OTA channels near Morganville, NJ
I have a HD TV and an old standard definition TV. I would like to get HD channels from NYC (or Philadelphia if possible).
My TVFOOL report is below:
http://www.tvfool.com/?option=com_wr...e07cff44984651
I need help with the following:
1. Type and Model of antenna. should I get roof mounted,
or attic mounted antenna?
2. Do I need a rotor?
3. can I share the signals between 2-TV sets?
4. Do I need a pre-amp?
your advice is appreciated,
Baud
saintbaud is offline   Reply With Quote
Old 15-Feb-2011, 5:21 PM   #2
TV Antennas and Reception
If the building the Tv is located in is wood frame with wood or vinal/plastic siding and the building does not have a metal roof then a Simple Non Amplified indoor tv antenna will receive the channels in green. http://forum.tvfool.com/showthread.php?t=233 , Here is inflammation of aiming Tv antennas , aim the antenna at about 30 degrees magnetic compass , http://www.kyes.com/antenna/pointing/pointing.html , Read and understand this about , Real Digital Tv Channels Virtual Digital Tv Channels , Analog Tv Channels , http://forum.tvfool.com/showthread.php?t=695. . If you will like to install a outside roof top Tv antenna then a ANT751 or simalar Simple VHF/UHF antenna.
