Old 15-Feb-2011, 1:34 AM   #1
kentrx1
rookie requesting antenna suggestion
Live in a heavily wooded area with all stations towers i am interested in getting located within 1 mile of each other approx 62 miles from my home. terrain i basically level with no nearby metal buildings. one station is high vhf band (11), the rest are in uhf. only have 1 tv connected and have a mast on house with ability to mount antenna approx 25 feet off ground. total coax cable lenth 50 feet. would appreciate suggestions!
kentrx1 is offline   Reply With Quote
Old 15-Feb-2011, 1:45 AM   #2
TV Antennas and Reception
Nice information , however the Most Important Information is missing , http://forum.tvfool.com/showthread.php?t=4 , As others have done , do not post a picture of the tvfool radar report , post the real live and active radar report.
Old 15-Feb-2011, 1:57 AM   #3
kentrx1
rookie....take 2
my apoligies on not posting the requested information. please reference this link:
http://www.tvfool.com/?option=com_wr...e07ca906bbf783
the group of stations at 181 degrees are the only ones that i am concerned about.
thanks again for your help.
Old 15-Feb-2011, 11:31 AM   #4
I suggest a Winegard HD7697P , should be enough signal for 2 Tv's.
Old 15-Feb-2011, 5:42 PM   #5
kentrx1
one more question....
thanks, just ordered what you suggested. do you think an amp will be needed or should the antenna suffice alone? i really appreciate you sharing your expertise.
Old 15-Feb-2011, 5:51 PM   #6
If the antenna is behind trees at 60 miles, your UHF reception will likely fail. You'll need one of these unless you can get a clear an unobstructed view to the southern horizon:
A pre-amplifier is strongly recommended in any event.
Old 15-Feb-2011, 5:59 PM   #7
If an amplifier is needed then Winegard AP8700 preamp
Old 15-Feb-2011, 6:13 PM   #8
kentrx1
thanks
thanks to both of you. will do a little trimming and see what happens. at least i know what to order if things do not work out initially.
