Old 22-Aug-2013, 9:23 PM   #1
doug4au
Need help selecting a new antenna
Well, it is time to replace my antenna that has lasted about ten years. I believe it is a Channel Master 3020, but don't hold me to that. It has done ok for me, but now I have all but lost reception. It has a couple of broken elements and I think the preamp is probably shot. My info is as follows:
Located in east central Alabama, hilly terrain and dense trees. I sit near the top of a tall plateau.
Antenna is on a 35' tower with a 5' mast (40' total), so I want to get this right the first time. The tower is anchored in concrete, bolted to the house, and grounded. The tower seems as solid as a rock and can be climbed, so I din't think the wind affects it. It has a preamp on the mast and another amp under the house.
I am running 2 TVs on it and there is about 100' of cable run from the antenna to the amp under the house.
I have a Channel Master digital rotar that works fine.
Here is a link to the interactive map results:
http://www.tvfool.com/?option=com_wr...46aee8f9edebaa
I have been picking up about half of these channels with the old antenna, rotating the antenna.
It is essential that I pick up the first 12 or so on the list (which I have been) and that includes a couple of high VHF channels. Any more channels would be a bonus, and if I can reach out there and get them, I'd like to try.
I want to get the best reception I can of course without breaking the bank. The biggest expense in my setup is the tower, of course, and I want to keep using it. I want a good quality antenna because getting up to it is problematic, to say the least.
Should I go with another deep fringe antenna or should I stack 2 seperate ones?
What type of pre amp?
What type of wire and connectors? (while I am doing this I am going to replace it all)
If I have forgotten anything let me know. Thanks in advance.
doug4au is offline   Reply With Quote
Old 23-Aug-2013, 10:30 PM   #2
Aim a Winegard HD7698P antenna at about 260 degree magnetic compass direction.
Use a Old School magnetic compass , not a smart phone compass.
________
Install a Winegard LNA-200 'Boost' XT amplifier.
________
http://www.solidsignal.com.
http://www.amazon.com.
My evaluation is All the Tv stations channels you require and many more should be received with the antenna aimed the direction of about 260 degree magnetic compass direction.
No antenna rotation.
Yes you can install the antenna rotator.
