Old 14-Feb-2011, 7:49 PM   #1
FlaEileen
Question Picking up far channels but not closer ones
I live in Pensacola, Fl. I have an indoor antenna (Philips SDV6122/27) which works pretty well. I can receive most channels on the list.
I can receive WKRG from Mobile, AL., which is 36.4 miles away just fine.
I cannot pick up WALA from Mobile, AL., which is only 34.7 miles away. (Missed the Super Bowl, dang it!)
Why am I not able to pick up a closer station? It boggles my mind. If anyone has advice as to a stronger indoor antenna, I would appreciate it. I rent and can't put up an outdoor antenna.
My TV Signal Analysis Results:
http://www.tvfool.com/?option=com_wr...e07ce416d1a67e
FlaEileen is offline   Reply With Quote
Old 14-Feb-2011, 8:32 PM   #2
I'd suspect FM overload.
WALA is on VHF channel 9. Your antenna does have a VHF rabbit ear section, but it has an amplifier. Strong FM stations can overload the amplifier.
You can try shortening the rabbit ear elements to 16" on each side, that will favor channel 9 while also reducing the FM signal strength. The other solution is to try an un-amplified antenna. Even then, 35 miles is far for an indoor VHF antenna.
Old 15-Feb-2011, 2:23 AM   #3
TV Antennas and Reception
Here is information of NON Amplified indoor Tv antennas , http://forum.tvfool.com/showthread.php?t=233 , Here is information of aiming Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html , Here is where to buy a Fm Trap for use with a NON Amplified indoor Tv antenna. http://www.mcmelectronics.com/product/33-341
Old 16-Feb-2011, 11:57 AM   #4
FlaEileen
Thanks for the replies. I adjusted the rabbit ears and turned the amplifier down. Didn't help. I may try the FM trap. If that doesn't help, I suppose I'll just live without channel 9.
Old 16-Feb-2011, 1:36 PM   #5
The FM trap won't help, as you need to place it between the antenna and amplifier, which you don't have access to. An unamplified version of your antenna is a simple rabbit ears/loop combo that would cost all of $12 at most.
Old 16-Feb-2011, 2:00 PM   #6
As Dave states, the FM trap won't help with your existing antenna. The FM trap needs to be between the antenna and the amplifier. Your existing antenna has an internal amplifier.
