Old 17-Aug-2013, 11:47 AM   #1
sobr0716
Antenna advice for Miami
All help is appreciated. I just cut the cord on cable and want to pull in some hd signals. What's my best route?
- metal roof
- close to high tension power lines < .25 miles
- would like to mount in attic. If possible
Here is my report...
http://www.tvfool.com/?option=com_wr...46ae2a81b99a35
Thanks in advance!
mark
sobr0716 is offline   Reply With Quote
Old 17-Aug-2013, 2:37 PM   #2
You don't need a large antenna, but the metal roof will reflect and block signals, making the attic a difficult or impossible mounting location.
The RCA ANT-751 or Antennacraft HBU-11 would do well, mounted on the roof or a wall. Point at about 28° per a compass, while avoiding trees, buildings and other obstructions.
If you have several TVs to connect, try using just a passive splitter. If you have trouble with some of the weaker signals you can add a CM-3410 distribution amplifier between the antenna and splitter.
Old 17-Aug-2013, 8:53 PM   #3
Your reception location has recivable Tv stations the directions of , North , North East , South West , South.
Above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , North , North East , South East , South.
Install a Channel Master CM5016 antenna aimed at about 14 degree magnetic compass direction.
Use a Old School magnetic compass.
A Winegard , DS3000 J pole type antenna mount will work well with the CM5016 antenna.
___________________________
A metal roof Will Reduce and Block Tv reception with antenna in attic.
A antenna system amplifier will most likely Not Be required for reception.
Yes , reception can be 'tested' with a antenna system amplifier connected between the antenna and splitter.
Use a Winegard , LNA-100 'Boost' antenna system amplifier.
_________________________________
http://www.solidsignal.com.
http://www.amazon.com.
________________
