Old 5-Aug-2013, 5:50 PM   #1
mscj
Post Next step: Antenna
Bought an indoor RCA rabbit ear type antenna(ANT 111F) for local stations and found I only received a fuzzy WCIU station.
Then found your site and found signal info: http://www.tvfool.com/?option=com_wr...46aebdd538fc3f
which to me seems to confirm I should be able to receive more stations.
Next I looked at my TV = Sharp lc-20sh6u 2006 LCD EDTV. Specs = TV STD – NTSC, TV Tuning sys – PLL 181 ch.
So here’s where I’m at: Maybe I’m not getting HD stations due to not having HDTV?, If I’m picking up some signal from WCIU, why not better signal? If I can pick up WCIU, why not other non-HDTV signals because they are being broadcast from the same local. Is there an inexpensive device to read which signals are available at a specific location?
Can anyone provide guidance on next steps? How do I proceed with minimal costs? Thanks
mscj is offline   Reply With Quote
Old 5-Aug-2013, 7:50 PM   #2
You now need an ATSC tuner. You'll either need a converter box or a new TV set.
Old 6-Aug-2013, 2:19 AM   #3
The Tv / Tuning Device , Must Be Capable of Tuning the , ATSC , aka , 8VSB , Digital Broadcast Tv stations/channels.
A NTSC Analog tuner will Not tune the digital broadcast tv stations/channels.
Here are some converter boxes.
______________________
RCA DTA800B1 .
http://www.epvision.com .
http://www.channelmasterstore.com .
Or buy a New Tv.
Put the simple RCA 111 , rabbit ears antenna in/at a window that faces , South East or South.
The main group of Tv stations is to the , South East.
Aim the antenna at about 150 degree magnetic compass direction.
Here is how to aim indoor and out door antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If the Tv is not in/at the window then run a Long coax from the antenna in/at the window to the Tv.
Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels.
Go into the Tv Setup Menu and select , Digital , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
________________________________
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc??
What directions do the , windows , patios , balconies , face??
What floor??
What is the top floor??
Last edited by teleview; 10-Aug-2013 at 11:29 PM. Reason: Clarify information and typos.
