Old 31-Jul-2013, 7:40 PM   #1
schmeckp
Ixonia, WI
Hi,
Looking to determine the best antenna to receive the top 12 stations from my tvfool report (94 degrees, 35 miles), and what setup you would recommend to split the signal to 4 TVs throughout the house.
The antenna will be roof mounted, about 20 ft above ground level (can go as high as 24 if needed. The cable runs vary from 35ft to 80ft in length, and they will be to 4 separate TVs. From the antenna, each tv is 35ft, 45ft, 60ft and 80ft (cable length) respectively.
20ft up:
http://www.tvfool.com/?option=com_wr...46ae480f8f06b0
24ft up:
http://www.tvfool.com/?option=com_wr...46ae4395e75f19
Appreciate opinions on antennas and splitter / amp setup.
schmeckp is offline   Reply With Quote
Old 31-Jul-2013, 8:36 PM   #2
The signal from WIWN on real CH-5 calls for an all channel antenna such as:
Winegard HD7084P
Channel Master CM3018
Antennacraft C490
Consider the following preamplifiers:
Winegard HDP-269
Antennacraft 10G201
Channel Master CM-7778
If the splitter must be located between the preamplifier (outside at the antenna) and the the preamp power supply (inside, protected from the elements), Antennas Direct offers splitters that pass power. http://www.antennasdirect.com/store/splitters.html If you don't need the power passing feature, Ideal brand splitters at Home Depot or Amazon will serve well.
Last edited by GroundUrMast; 31-Jul-2013 at 8:40 PM. Reason: power passing splitters
Old 31-Jul-2013, 10:07 PM   #3
The current Tv channels that are being transmitted and received in , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has Tv channels in all 3 Tv bands.
Some of the Tv stations signal strengths are Weak signal strength at your location.
Recommond install a Large All Channel Tv antenna.
Recommend
Above the Peak of the Roof in such a manner that the roof and building are not impeding and blocking reception in the directions of , East , West , North.
Install a Winegard HD7084P All channel antenna aimed at about 95 degree magnetic compass direction.
_____________________
Install a Winegard AP8700 preamp.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at solidsignal.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.ronard.com.
Here are some strong and sturdy antenna mounts.
Use the 5 foot tripod antenna mount. ronard(911) .
Measure chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) , chimney mount.
Buy the ronard antenna mounts at solidsignal by typing , ronard(x) , in the solidsignal search box or buy from ronard.
___________________________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv Reception.
Multi-path/reflections bouncing off the trees and tree leaves.
Trees and tree leaves absorb Tv transmissions.
Trees and tree leaves block Tv transmissions.
____________
The Best Practice is to install a Tv antenna at a location that has the least amount to no amount obstructions of any type or kind in the directions of reception including your own roof and building.
____________
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 1-Aug-2013 at 4:38 PM. Reason: Clarify information and typos.
