Old 23-Jul-2013, 9:59 PM   #1
Clemons29
Help choosing antenna
Trying to cut the cord and need some help picking the right antenna. I have a DirecTV dish mounted on the roof and would like to replace it with an antenna. I think by what little I can understand from my location report that I will need a multi directional antenna, however I have no clue what one I should buy that will work well and fit into the mounting bracket. My link is: http://www.tvfool.com/?option=com_wr...46ae21de24dbfa
Any help would be appreciated
Clemons29 is offline   Reply With Quote
Old 24-Jul-2013, 1:38 AM   #2
A Simple reception situation.
For reception of the Local Digital Broadcast Tv stations/channels in the Green reception zone of the tvfool report.
Install a Channel Master CM4220HD antenna above the roof in such a manner that reception is not impeded and blocked by the roof and house in the directions of , East , South East , South.
Aim the CM4220HD antenna at about 150 degree magnetic compass direction.
___________________________________
No antenna system amplifier is required.
http://www.solidsignal.com.
http://www.amazon.com.
Disconnect and Remove satellite system passive and active devices such as and not limited to , multi-switches , multi-plexers , splitters , combiners , amplifiers , power injectors , power supplies , and etc. .
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
____________________________________________
Last edited by teleview; 24-Jul-2013 at 3:15 AM. Reason: Clarify information and typos.
Old 24-Jul-2013, 2:22 AM   #3
Clemons29
Thanks for your help!
