Old 23-Jul-2013, 8:53 PM   #1
Drogith
Manch Vegas NH looking for some help
Hello everyone! Just like many here, I am looking to be rid of my cable bill. My family only watches 2 channels consistently and anything else is just time killing. I live in Manchester NH and am looking for an inside antenna that will go out to about 20 miles, that's it. Based on my area, I did several maps with elevations ranging from 1-50ft (2 floor + atticish space and basement) and I'm looking for the best option. I am also looking to keep this as inexpensive as I can.
1ft
http://www.tvfool.com/?option=com_wr...46aecb32ab8873
10ft
http://www.tvfool.com/?option=com_wr...46ae9e2e430982
30ft
http://www.tvfool.com/?option=com_wr...46ae1815007860
50 ft
http://www.tvfool.com/?option=com_wr...46ae390d9f4230
Drogith is offline   Reply With Quote
Old 24-Jul-2013, 4:14 AM   #2
What are the 2 channels/networks that the family watches??
Using a smaller type antenna.
In the Green and Yellow reception zones , this is what will be received.
WMUR , ABC and Me-Tv.
WNEU , Telenundo.
WUNI , Univision.
WENH , PBS channels.
WYCN , Religion.
WBIN , IND. and LWN Live Well Network and Weather Nation.
WUTF , Unimas.
W39AR , is the same as WYCN.
WPXG , ION and Qubo and ION Life.
__________________________________
If the reception of .
WBZ , CBS .
WHDH , NBC and This Tv.
WLVI , CW and ZUUS Country.
WFXT , FOX and Movies.
Are also required , then a Big Antenna Above the roof is required.
Last edited by teleview; 24-Jul-2013 at 2:06 PM. Reason: Clarify information and typos.
Old 24-Jul-2013, 12:37 PM   #3
Drogith
Ion and WENH
The only other channel we watch occasionally is WMUR, but that station is literally right up the road, so I'm not too worried about that one.
Old 24-Jul-2013, 2:10 PM   #4
For reception of the 3 Tv stations you have listed. AND MORE.
Install a ANT751 antenna aimed at about 41 degree magnetic compass direction.
Last edited by teleview; 26-Jul-2013 at 6:57 PM. Reason: Clarify information and typos.
Old 26-Jul-2013, 1:36 PM   #5
Drogith
Is there an internal type? or can this be attic installed? Coaxial connection?
Old 26-Jul-2013, 7:02 PM   #6
Yes you can start with the ANT751 in the attic.
If reception situation/problems happen that are not resolvable by adjusting the ANT751 antenna aim and location in the attic.
Then move the ANT751 to above the roof.
Yes ->common<-> RG6 coax is connected to the ANT751 and then the coax is connected to the Tv.
Old 28-Jul-2013, 8:03 PM   #7
If you will like to receive Many More Tv stations/channels.
Above the Peak of the Roof install a Winegard HD7698P antenna aimed at about 185 degree magnetic compass direction.
Buy the HFS splitters at , http://www.solidsignal.com.
