Old 20-Jul-2013, 4:29 AM   #1
at_hiker
Antenna selection for Clayton, NC
I'm in the process of trying to "cut-the-cord" from DirecTV and use a OTA HD antenna and Tivo combination.
I want to do this right, so I don't just want to buy some random antenna. I want to make sure I get the best reception that I can.
Here is my reception analysis:
http://www.tvfool.com/?option=com_wr...46aed3ee0ee2cb
Most of the channels that we would watch are in the green/yellow zone, and I believe most of them are broadcast from a group of antennas about 10 miles from my house. I would like to get some channels outside of this zone if possible. I have been leaning towards a Channel Master CM-3000HD antenna mounted in my attic.
Is there an antenna that would better meet my needs?
Thanks,
Steve
at_hiker is offline   Reply With Quote
Old 20-Jul-2013, 7:21 PM   #2
-->As always<-->attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Multi-path/reflections Tv signals bouncing all around.
Absorbing Tv signals.
Blocking Tv signals.
_______
Above The Peak Of The Roof in such a manner that reception is not impeded and blocked by the roof and building in the directions of , North East , North , North West , West.
Install a Channel Master CM2016 antenna , aim the CM2016 at about 34 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
_______
A Winegard , DS3000 , J pipe type antenna mount has flexibility of use for installing the CM2016 and other antennas.
_______
Install a Winegard , LNA-100 'Boost' , antenna system amplifier.
_______
_______
http://www.solidsignal.com.
http://www.amazon.com.
________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv reception ,
multi-path reflections ,
absorbing ,
blocking ,
reception and so do buildings including your own roof and house and other obstructions in the directions of reception.
The Best Practice is to install a Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
_______
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
________
If little to no importance concerning or understanding of obstructions to reception.
If not willing or able to avoid obstructions to reception.
Then install a bigger antenna for more reception ability of a bigger antenna.
Install a Winegard , HD7698P antenna.
___________________________________
Old 21-Jul-2013, 7:49 PM   #3
at_hiker
teleview...thanks so much for your recommendations. I'm confused about one thing. If most of my local channels are at 5 degrees (Magn), then why would I aim the antenna to 34 degrees? There aren't many channels in that direction.
Old 21-Jul-2013, 9:16 PM   #4
WRPX-DT Real Digital Uhf channel 15 ION at 34 degree magnetic compass direction is Weak Signal Strength.
The other Digital Tv stations/channels , On Up the channel list are stronger signal strength.
Old 22-Jul-2013, 1:12 AM   #5
elmo
Call me old school but I'm skeptical of antennas hidden away in plastic. To me that's a sign that they know they couldn't sell you on a thin film of aluminum for $50. That's not to say it won't work for you. At 10 miles LOS, it won't take much to tune those stations from the north.
