Old 27-Jun-2013, 8:30 PM   #1
brooks1083
Reception in Alabama
Ok, so here is what I have, I'm currently using a pc with an infinitv card that uses cablecard to DVR Comcast. I don't watch a lot of tv but I'd like to pick up my locals and anything else would be a bonus. I need to be able to put the antenna in my attic, new home/neighborhood. The peak of my roof is probably 20 ft off the ground with regular shingles. I know I will need to get a new tuner card (probably like a hauppauge 2250). But I need some good advice on an antenna and, if necessary, an amp. Like I said, mainly getting local affiliates is my primary concern, but if getting a better antenna will pick something extra up (besides a redundant affiliate) I would definitely do that.
Here is my report (just so you know, WRGX is now an NBC affiliate):
http://www.tvfool.com/?option=com_wr...055935649acfb1
brooks1083 is offline   Reply With Quote
Old 28-Jun-2013, 2:31 AM   #2
As always , attics and inside buildings are/is not a reception friendly environment and never will be a reception friendly environment.
Multi-path/reflections signals bouncing all around , absorbing , blocking , broadcast Tv reception.
____
Here is the Federal Antenna Law that says Yes you can install a Broadcast Tv Reception Antenna of Any Size Above The Roof in such a manner to have Reliable Broadcast Tv Reception.
Start with a ANT751 antenna in the attic aimed at about 194 degree magnetic compass direction.
Also install a Winegard LNA-100 'Boost' amplifier.
______________
If there are reception issues that are not resolvable by adjusting the aim and location of the ANT751 antenna in the attic.
Move and install the ANT751 antenna to Above The Peak Of The Roof in such a manner that reception is not blocked by the roof and house in the directions of , south west , south , south east , north.
Above the roof aim the ANT751 at about 194 degree magnetic compass direction.
With the ANT751 antenna above the roof , Test reception , without and with the LNA-100 amplifier. Might not require the LNA-100 amplifier with the ANT751 antenna above the roof.
____________________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast Tv reception and so buildings including your own roof and house and other obstructions.
It is best practice to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
_______________________
Here are some alternatives to computer tuner/recorders.
http://www.epvision.com , Tuner/Recorders.
http://www.channelmasterstore.com , Tuner/Recorders.
_____________
The ANT751 antenna Can Not be connected to any coax that has active cable delivered services , cable tv service , cable internet service , cable phone service.
Yes coaxes that are in or on the house can be used or antenna distribution.
Active cable services Must Be on Separate coax.
