Old 25-May-2013, 12:47 AM   #1
SCTVFool
Any chance for L.A. reception in San Clemente?
Any hope for us? Any suggestions would be appreciated. We are installing in our upper attic. Here is our Signal Analysis.
http://www.tvfool.com/?option=com_wr...1ddaf41ff082a0
Thanks for any information you can provide to help out!
SCTVFool is offline   Reply With Quote
Old 25-May-2013, 8:45 PM   #2
The reception of the L.A. area Digital Broadcast Tv stations/channels to the northwest are weak signal strength and will require a Winegard HD7084P antenna installed Above the Peak of the Roof in such a manner that the roof and house are not blocking reception to the north west.
Aim the HD7084P antenna at about 323 degree magnetic compass direction.
Here are some strong and sturdy antenna mounts.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
http://www.solidsignal.com.
http://www.amazon.com.
__________________________________________________
For 1 tv connected use No splitter.
Buy the HFS splitters at http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a negative effect , multipath-reflections , absorbing , blocking , Tv reception and so do buildings and other obstructions including your own roof and house.
The Best Practice is to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind of the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select the 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Old 31-May-2013, 6:32 AM   #3
SCTVFool
Thank you!
Thanks for such a thorough reply. We appreciate your time. Sounds a little daunting but we'll see if we can make it happen.
Old 5-Jun-2013, 4:01 PM   #4
A bit late to the thread, but my suggestion is to use a 7-51 antenna and focus on the San Diego stations. No pre-amp is needed.
Since you have a significant hill in the immediate direction of LA, your TVFool plot is likely overestimating those signals from LA and they likely are not even there.
